Drivetrain
02 LS1 33k
TEA ported 5.3l heads
Cometic .066 MLS gaskets
Patriot Extreme Dual springs .660 lift
LS2 timing chain
Wazees power steering and tensioner pulleys
Patric G cam
Katech ported oil pump
Katech rod bolts
ARP Head bolts
LS6 Valley cover PCV conversion
Fast 92 intake
Fast 92 TB
42lb SVO injectors
Aluminum Rails
Pro 5.0 short shifter
Remote clutch slave bleeder
Magnecor 8.5mm plug wires
Plug wire heat boots
Remote Bleeder
Brakes
Rz calipers
Rz 2 piece rotors
Ss lines
Speed beeders
Hawk pads
Us brake master
Suspension
New oem shocks
Swift springs
New shock mounts
New rear swaybar
New front swaybar bushings
RE trailing arms and Toe Links
Chassis
Supra Denso Fuel Pump
RS surge cover
Samberg mounting equipment
Paul 3rd gen rear subframe
New diff bushings
3:90 diff
New Raxels axles
Corvette FPR
Rotary Extreme toe links and trailing arms
New pillow balls
New SuperPro bushings
New SuperPro ps rack bushings
All new oem Mazda hardware
New wheel hubs and bearings
19" Volk TE-37's
Bridgestone Pole Position tires
Exhaust
Ceramic coated merge collector headers
RB dual tip exhaust
Dyno Numbers
Car made 443HP and 423TQ at the wheels on a load bearing dyno
