April 26, 2024, 06:29:28 AM
Author Topic: DIY FD harness hookup instructions for dummies  (Read 16774 times)
Offline danzan
  • Life is too short to drive a grocery cart
« on: May 10, 2010, 07:10:14 AM »
This instruction is to be used ONLY with my mod instruction titled "Basic harness mod"
DO NOT USE THIS INSTRUCTION WITH GRANNYS HARNESS MOD
http://www.norotors.com/pdfs/Harness%20hookup%20FD.pdf
« Last Edit: September 26, 2023, 10:30:39 AM by digitalsolo »
When the shit hits the fan, you'll find out who your friends are.
Offline AHarada
Re: DIY FD harness hookup instructions for dummies
« Reply #2 on: August 22, 2010, 11:28:41 PM »
The updated link for the PCM pin assignments does not have working pictures.  Is there anywhere I can see these pictures?
[smg id=6954]
Offline danzan
« Reply #4 on: August 23, 2010, 09:18:16 AM »
I think you should send your harness to brismo7. He lives close to you and you will get the lowest price I know of, for a quality basic mod.
I think, from reading your posts, that you may FUBAR.
Offline BeatTheTunaUp
« Reply #5 on: January 19, 2011, 09:34:23 AM »
Quick question.  I want to get rid of the relay box on the core support up front where the fuel pump relay is now.  I was reading the directions and kinda confused.  Is image 6 for leaving it all alone and image 7 an alternate way?  Can I just run the green wire from the ecu to a relay in the hatch for the fuel pump?  I assume the green ecu wire is hot when turned on?  If I move the relay to the rear, can I completly remove the relay box up front?
93 FD money pit
15 Ram 1500 Sport 4x4
98 Baja 192 Islander  5.7 vortec On the water
Offline ProjectD
« Reply #6 on: June 16, 2011, 08:55:45 AM »
Link is no longer working  :(
« Reply #7 on: June 16, 2011, 09:45:07 AM »
Which link?  They both just worked fine for me?
Offline ProjectD
« Reply #8 on: June 16, 2011, 11:37:11 AM »
The link in the OP by danzan. When I click with tapatalk it I get this error
And when I click it on my PC it just doesn't load.
Sent from my iPhone using Tapalk
« Reply #9 on: June 16, 2011, 11:47:01 AM »
Hmm, loads fine for me?    Not sure what to do there, tried it from 4 systems now.
Offline thetastelingers
« Reply #10 on: June 16, 2011, 11:59:33 AM »
All I get is a blank page.
wazzaaaaaaaaaaaapppppp!
Offline Speedfab
« Reply #11 on: June 16, 2011, 12:08:59 PM »
Worked fine for me, albeit slowest download I've seen since the days of dialup.
Sent from my desk using a keyboard.
« Reply #12 on: June 16, 2011, 01:13:22 PM »
It's a BIG file.   I'll see if I can shrink it down in size, it doesn't need to be so large.    That might be the issue.
Offline ProjectD
« Reply #13 on: June 16, 2011, 01:18:56 PM »
I just tried again and it worked.  Thank you sir!
Offline jaded-7
« Reply #14 on: May 25, 2012, 08:57:39 AM »
What part of this can't be used with the granny's wiring?
I believe i set up my fuel pump according to granny's, by passing the front relay, and re wiring the relay by the drivers side shock tower. All of a sudden (of course just as i fixed another problem) my fuel pump won't prime. Was thinking of just wiring up a new relay per instructions above.
