May 03, 2024, 02:16:45 AM
Author Topic: Updated pictures.& Specifications. 1989 Turbo II LT1 Stroker T56 .  (Read 18704 times)
Offline mpcv2000
( 2012-2013 updates on page 2 )
This thread is about my project car that started in 2009 but documentation really started March 2011 and more pages are added over the years to keep everything in one place as a reference for me or other using Google looking for info or idea for similar project.
This is the 2nd winter I work on my 1989 Turbo II and here's how it sits as of March 12 2011.
Specifications :
Lloyd Elliot LE2 package. www.Elliottsportworks.com
-Fully Ported heads milled 0.030" with 0.56cc chamber, casting 10128374.
Manley 2.00/1.56 6000 series valves.
PAC 1218 bee hive springs (145 lbs seat and 340 lbs open)
Steel retainers and locks.
205 cc intake port flow about 275/190 CFM.
-12.05:1 Comp. Ratio , 230PSI Compression.
-CompCams Pro-Magnum Roller rocker 1.6:1 7/16" studs "NSF" (None Self Aligned).
-850-16 CompCams Hi-energy hydrolic roller lifter.
-7937-16 CompCams Hi-Tech Pushrods 5/16"X7.050".
-MR-1896 Sealed Power 5/16" Guide Plate.
-Fully ported Intake manifold casting 12552138.
-AS&M 58mm Throttle body.
-Ford Racing SVO 30 Lbs. Injectors.
-Custom camshaft 223/230 .565/.565 112 LSA .
-Fel Pro 1074 head gaskets .039".
-Fel Pro 1284 intake gaskets.
-Autolite #104 0.030".
-Hypertech 160 degree thermostat.
-MSD 83811 Pro-Billet Distributor.
-MSD 8226 Blaster coil.
-MSD 32149 8.5mm Spark plug wires.
-TPIS High flow mass air sensor housing.
-Meziere WP118HD Electric Water Pump.
-Holley 255lph fuel pump.
-Hedman 69640 modified for Fastburn "d" style GM exhaust port to 2.5" into 3" N1 Pipe to Magnaflow Muffler.
-Ford Taurus V6 3.8L electric fan conversion.
-Shortblock : Link of the built.
-385CI ( 6.3L ) LT1 4 Bolt main Corvette shortblock.
-Scat 9000 stroked lightweight forged crank.
-Scat forged rods.
-Mallory Forged Pistons -5cc.
-4045MS-15 .040" + .005" Mahle rings file to fit.
-Rings gap : 1st .018" , 2nd .020".
-ARP main studs.
-Melling 10555 High Volume Oil pump.
-Clevite 77 MS-909H STD bearings crank Bearings.
-Clevite 77 CB-663H STD Connecting rods bearings.
-12370835 GM single roller extreme duty timing chain set.
-Fluidampr Harmonic balancer # 740101.
-Balanced and Blueprinted.
-Cleaned, decked, bored .040 over and honed with deck plates, new frost plugs, etc.
-Transmision T56 6 Speed.
-Fidanza #198581 12.5LBS flywheel.
-SPEC 3 clutch 11" 26 splines.
-Centerforce 381039 clutch disc.
-Ram BA381 HD clutch pilot Brg.
-GM OEM release Brg. 10085246 (CT1080).
-Pro 5.0 Short throw shifter.
-Dorman #31052 Pinion snubber
-Abbott Electronic speedo converter.
KAAZ 1.5 Differentiel limited slip 4.10. Diff built up link
Suspension/Wheels
Stance GR + Coilovers adjustable with front/rear pillowballs.
Racing Beat DTSS Elims.
K2RD Rear Camber Adjuster.
Front STB.
5Zigen FN01R-C 17x8 +25 225/45/17 Nitto NeoGen.
5Zigen FN01R-C 17x10 +35 275/40/17 Nitto 555R Drag R.
Toyota MR2 Electric Power steering conversion.Detailled info here.
Car weight with full interior ( March. 2011 ).
2888 Lbs.
« Last Edit: September 08, 2013, 05:40:07 PM by mpcv2000 »
Martin !
Offline whitehot
Geez, that thing is crazy clean, as is your shop.
Here's mine haha.
-Scotty
-88 TII -- forged 355 LT1/T56
Offline WannaBeFast
  • Single and Looking
Man that's clean - do you live in vacuum?
Offline mpcv2000
I have about 600+ hours in the car since Nov. 2010.
It's a hobby , I love it. :cheers:
Martin !
Love it!  Something about FC's and FN's do it for me :)
Offline mpcv2000
Martin !
Gorgeous car!  Why hasn't this been nominated for car of the month yet?
That is looking fantastic.    I've said before, this is one of my favorite FCs.   :)
Offline mattster03
makes me want to build another LT1/T56 FC... hmmmm
wow!  That is one clean FC.  Your garage is pretty damn impressive too!
Offline mpcv2000
Re: Spring 2011. Updated pictures.& Specifications. 1989 Turbo II LT1 T56 .
« Reply #10 on: March 14, 2011, 08:36:48 PM »
March 14 2011.
Idle and walk around video here : ..clic me..
 :drive:
Martin !
Offline Brismo7
  • I need 6000cc of LSx!!
« Reply #11 on: March 17, 2011, 12:15:13 AM »
Wow!! That is seriously one of the nicest FC's i've seen.  Great job!
Offline mpcv2000
« Reply #12 on: March 17, 2011, 06:08:52 AM »
Thanks guys. :)
Martin !
Offline thetastelingers
« Reply #13 on: March 17, 2011, 07:07:09 AM »
I was going to say this. ^
wazzaaaaaaaaaaaapppppp!
Offline bz7
« Reply #14 on: April 26, 2011, 05:23:08 PM »
Awesome build! I wish my LT1/FC looked like this!
What parts did you use for your intake setup? I really like it. Right now mine is just a 3.5" K&N directly on the MAF :D
Also, are you Hedmans ceramic coated? If so, where did you get this done at? I'm debating on whether to bother doing it to the Edelbrocks laying in my garage.
Again, kudos on a super clean ride!
