She moved under her own power yesterday:
Basic still need to do's:
Get the rear ride height sorted
Move driveshaft loop forward
Mount seat
Get a hood and cut down the dump tubes
Mount Fire suppression system
Not so basics:
The trans brake works but it's not bumping in. Not sure if the issue is the relay, MS3 settings or what but I don't really want to stay on the brake in order to troubleshoot. Right now, I've got the 12V going through one button on the wheel going to the NC part of the relay which goes right to the TB. I'm using this 12v supply (pre-relay) to signal the MS3 (launch in) and to feed the other button. The second button goes to the MS3 (bump input) and I'm using the MS3 bump output (ground) to ground the coil on the relay.
EDIT: now that I think about it, I was only at like 25% throttle. Need to check the settings.
The other issue is the oil pressure. In the FD (same motor/ turbo) I was seeing ~35 psi hot. In this car I added an oil cooler (stock FC unit) and now the oil pressure is ~25 psi hot. High volume pump, -10AN lines, 10-40w oil. It rises with RPM like it should (10 psi per 1k rpms per manual) but still a little low for my liking. I may try straight 40w since I dont drive it in the cold anyway.
