Finally got around to posting some pics. This is for my FD. I plan to flock it once I am done with the fiberglass, which should be very soon. I trimmed the width of mine for a future roll cage going down the A and B pillar. The dash mounts to the bar with aluminum tabs on the L and R side and also one in the center.
Covered stock dash in aluminum foil and began laying epoxy then fiberglass
Taken off, trimmed, fitted
using carbon fiber for my center switch panel and gauge cluster. The gauge cluster will mount to the bar behind the dash.
I skipped posting a lot of sanding/trimming pics, but a lot of work was done to make it here.
Semi-final form before flock, mounting check
Cluster still needing check engine light and turn signal indicators.
