Chassis
1993 Chassis, no sunroof - 2470lbs with 7 gallons of gas
Carbon fiber hatch, with plastic window
Chassis stripped, sand plasted and power coated white inside and out
Front end has tube bracing, and tube bumper, splitter support and integrated radiator mounts
Custom Firewall behind driver
Full TcDesign Cage (1.5" x120 wall) - SCCA legal with logbook
Fiberglass doors - gutted 14lbs
7sParts 1 piece fiberglass nose to fit 18x12 wheels and 335 front tires
Manual Steering rack from Mavel with Custom bumpsteer kit
Fuel Safe fuel cell with pump and surge box 15 gallon
Momo Steering wheel
Plexy windsheild
Braile 11lb battery
Aluminum Dash with oil temp, oil pressure, water temp and fuel pressure gauges
cutouts for DL1 logger and Dash2 display
Suspension
ALL Suspension arms with Delrin Bushings
Front Samberg Subframe powdercoated black
JRZ triple adjustable shocks 900/1000, fresh rebuild - 1 season from complete rebuild
Tripoint Front Swaybar with Widefoot Mounts, both .195 and .095 wall center sections
Wheels
18x12 CCW C10 wheels x4 with Hoosier Slicks
Engine
630 hp LS7 Sleeved with LS3 heads 438Cu in
12:1 Compression
235/242 x115 cam
Ti LS7 Rods
Manley dual springs and Manley hollow stainless intake valves, solid stainless exhaust valves
LS3 Intake
92mm PTM Throttle Body (cable driven)
LS9 injectors
Aviaid 3 stage dry sump system with fresh rebuilt pump, all new lines, all XRP filttings
Aeromotive fuel filter, Fuel pressure regulator, and AN6 line for LS1
LS1 Race Harness - No Transmission wiring
Transmission
G-Force 4 SPD Dog Box transmisison from nationwide car
Quartermaster Triple Disk clutch
Quartermaster flywheel
Tilton 2.2Hp Super Starter
Quartermaster Bell housing
Custom aluminum driveshaft for Ford 8.8 rear end
Rear End
Ford 8.8 with Torsion T2R
All new bearings
Samberg install kit
Rear Subframe
DSS Axles
Subframes are powdercoated black
Complete with cooler, fan and Tilton pump. New lines and AN fittings
Rear end Breather tank
Aerodynamics
G-Stream Carbon Wing with uprights
Large alumalite front splitter with integrated supports - very sturdy
Brakes
Tilton 600 series pedal box, 76 series master cylinders, Tilton Reservoirs
All AN brake lines with Stanless AN fitting throughout
Honda S2000 ABS plumbed, but needs wiring
Brembo 13" 4 Piston Front Brakes
Raybestos ST41 Front Pads
Wilwood 4 piston Rear Brakes with Racing Brake Rotors,+ 1 set of spare rotors
Raybestos ST45 Rear Pads
Data Acquisition
Race Technology DL1 Datalogger with Dash2 display
Safety
Sparco Ultra Seat
Longacre Window Net
2.5lb Safecraft fire extinguisher
Schroth Profi III 6 point harness
Exhaust
Hinson Steel Mid Headers
Hinson Steel Y pipe
Hinson 3.5" mild steel exhaust
Haulmark 24' Trailer and 2000 F250 truck also available
Asking $40,000
