Appreciate the responses, I went ahead and ordered the diff mounts, and the pbm sub frame mounts. You're right, $200 for 2 sub-frame mounts is silly. Hoping this will remedy my issue. I'll update in the next week or so when they arrive and I get a chance to test it.
I have the Mazdatrix Pro Differential bushings and PBM spherical bushings in my setup now. I am also using the spacers made by Bowtie7 on top of the PBM sphericals to make them the same height of the original subframe mounts. I also run the PBM camber arm to aid in camber adjustmentI used to have solid subframe mounts with the Mazda Pro differential bushings and the stock subframe camber arm when I first installed my 8.8. Everything lined up perfect during the original install and continued to be the same after the installation of the MAX spherical subframe mounts and adjustable camber arm.A 5/16" misalignment seems a bit too much, specially when nobody else has run into this issue before. Is there a possibility your subframe could be bent?
Sell it to spacevomit. He'll finish it.
They are very simple Delrin or UHMW spacers.Contact these guys Via Ebay. They have or did have subframe mounts. Their diff and subframe mounts may be interchangeable, I do not remember for sure.http://www.ebay.com/itm/Rx7-Rx-7-FC-Rear-Solid-Differential-Mounts-Turbo-FC3S-/110906828507?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d28fe6db&vxp=mtrAsh, those are the standard Delrin subframe bushings. The pieces we had done drop in to the upper portion of the PBM 2 piece bushings to make them stock thickness. PBM bushings were made to raise the subframe up for the slammed drift cars effectively changing roll center but not really in a good way for us especially when running bigger tires. I think I had some pics of bushings on here somewhere.
Quote from: largeorangefont on April 07, 2015, 02:52:56 PMThey are very simple Delrin or UHMW spacers.Contact these guys Via Ebay. They have or did have subframe mounts. Their diff and subframe mounts may be interchangeable, I do not remember for sure.http://www.ebay.com/itm/Rx7-Rx-7-FC-Rear-Solid-Differential-Mounts-Turbo-FC3S-/110906828507?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d28fe6db&vxp=mtrAsh, those are the standard Delrin subframe bushings. The pieces we had done drop in to the upper portion of the PBM 2 piece bushings to make them stock thickness. PBM bushings were made to raise the subframe up for the slammed drift cars effectively changing roll center but not really in a good way for us especially when running bigger tires. I think I had some pics of bushings on here somewhere.
