Never installed Samberg 8.8 kit to be used with this Cobra differential & Cobra axles that need to be adapted.
8.8 mount kit, cobra diff, cobra axles - $1750 shipped
From my research here, this is what is need to complete the swap. Perhaps someone can chime in to confirm!
1. Axles need to be modified. Utilize the cobra inners with the rx7 outer section.
2. If using a 93 subframe, have to weld in the plates in the center of the 1st picture above to make it a bolt in experience. See picture here of where they attach to the subframe:
https://www.norotors.com/index.php?topic=6024.0 1994-1995 already have this piece on the subframe.
3. Diff cover needs to be ground down, also seen in that picture above.
4. You would need a replacement driveshaft to mate which ever transmission your using to this differential. driveshaftshop.com is one option
5. Since this would get rid of the PPF you need a transmission mount. Many options out there depending which transmission your using.
In the pictures I see wires and a magnetic pickup or two. Is this for electric locking? If so, did this come factory for the cobra and is to be used in the swap car?
Those are the abs sensors. You can see the inner portion of the axles have the abs wheels that run along the mag pickup.
