Cage came in today and I got started. The kit is designed to be mounted to the floor pan but I opted to secure the main hoop to the frame rail for two reasons: to allow for more seat room and well, its seems stronger and when the shit hits the fan I want strong.
I started by cutting and mounting the plates to the frame rail:
Next I measured quite a few times (found out one leg of the hoop was slightly longer) and cut. VERY snug right now - not even welded and stays put. I may take off a little to keep it from rubbing.
Pretty much all of the bends and notches are spot on except for the halo bar (will need to be cut down). A few things I've learned so far is that the factory seam glue WILL catch on fire, which can be a little disconcerting when it happens near fuel lines. That thin sheet metal in the hatch area sucks ass- definitely have to focus the heat on the mounting plate and then pull it down slightly to the thinner metal.
I'm not sure at this point if I'm going to install the halo bar or not since a 6-point will get me to a 10.0 or 135mph which is probably fine for this season. The only reason to go 8 point now is to avoid the hug pain in the ass down the road.
I'll update this as I go.
