May 18, 2024, 09:45:18 PM
Author Topic: t56 magnum shifter  (Read 5495 times)
Offline Negrok20r
t56 magnum shifter
« on: November 23, 2014, 05:28:56 PM »
I decided to fab my own shifter since the one I had was leaking oil and I didn't like the way it felt
I used a 7/16 thick aluminum plate
I moved the shifter arm 5" 1/2 back from center to center , that's the number I came up with
I added a "O" ring on the top part with a washer and a boot on the bottom
installed on the tranny , went thru the gears and they all went in . now I just need to take the car for spin .
the idea is great I hope it works  :)
installed
« Last Edit: November 23, 2014, 05:44:52 PM by Negrok20r »
dc2 k20 turbo
93 FD under construction
Offline Bowtie7
Re: t56 magnum shifter
« Reply #1 on: November 23, 2014, 06:31:14 PM »
Looks pretty cool! I have transmission envy.
I do love what I do!
Offline UH-60Pilot
« Reply #2 on: November 23, 2014, 07:26:14 PM »
Looks similar to Sikky's shifter, which is what i'm running on my magnum.
1997 Miata K24Z3 swapped.
1977 GMC K10 with LQ9 swap.
Offline Negrok20r
« Reply #3 on: November 23, 2014, 08:16:03 PM »
Does yours leak? I had a sikki before and leak a lot.
Sikki has 4" offset if I remember correctly .
I just test drove the car about 30miles  and is day and night difference..
The travel of the shifter is about 3/4 compare to the old one I had  it was really annoying because the travel felt like it was going up to 1st and way down to 2nd
dc2 k20 turbo
Offline Ls1-fd
« Reply #4 on: November 24, 2014, 02:15:16 AM »
All you need to do is modify the stock shifter to work in the FD. Much better than Sikky shifter and it's free.
Turbo LS9 RX7
Offline Ls1-fd
« Reply #5 on: November 24, 2014, 02:21:32 AM »
Turbo LS9 RX7
Offline UH-60Pilot
« Reply #6 on: November 24, 2014, 07:55:00 AM »
Yes the first batch of Sikky shifters leaked. I waited a year for them to come out with a new version that fixed the leak. So no more leaks.
Offline Todds94FD
« Reply #7 on: February 09, 2015, 02:35:27 AM »
where did you buy those parts from and who makes them?
I've been searching but can't find anything.  I'm sure I'm just using the wrong search words
94 RX7 (build in progress)
EVO 9: 750HP (SOLD)
135i: 455 TQ (Sold to feed my FD habit)
Offline Mik3ymomo
« Reply #8 on: February 09, 2015, 12:50:30 PM »
http://lmgtfy.com/?q=Sikky+shifter
93 CYM Base Single Turbo
93 BB Touring 20B Swap (Sold)
Offline UH-60Pilot
« Reply #9 on: February 09, 2015, 01:13:50 PM »
^ I think he is talking about the parts to make the shifter. Not wanting to know where to buy the sikky shifter.
« Reply #10 on: February 09, 2015, 01:40:19 PM »
I sell the bar stock that was used to modify the stock T56 Magnum shifter.  I've driven them all.... and this one feels better than even the Sikky.  But if you want to spend $500 for the Sikky please do so  :D
Offline Todds94FD
« Reply #11 on: February 09, 2015, 05:17:19 PM »
hahahaha, Sorry I should have been more clear.
I was actually talking about the shifter the OP made.  I've found out where the parts come from.  By the time you get the plate made, you wouldn't be saving much over buying the Sikky.
Sorry, I wasn't talking about where to buy the Sikky shifter.  I had one of the original ones for the Magnum and had problems with mine.  I returned mine and got the ball rolling on their revised version.  I was curious if all the problems were finally fixed.
As far as modifying the stock Tremmec shifter.  I am really considering that also.  I'm just not sure if I'll have the room without modifying the tunnel more, which I prefer not to do.  I may do it anyway and give it a shot.
I'm just looking for something different than my Redline Shifter that I'm currently using.
Thanks everyone
EVO 9: 750HP (SOLD)
