Car is currently in Holland awaiting transport back to the UK.
Attended a trackday at Zandvoort. 90degF ambient which is the hottest the car has ever experienced. Did a couple of sessions. 2nd session the water peaked at 230degF and oil at 268degF(pre cooler). Samberg rad, single stock oil cooler with 99 bumper. Had the air con on also.
When the water temp peaked I ran 2 laps to cool it down before coming in. At low revs in top gear the oil pressure alarm (Spa gauge) pinged at 7 or 8 psi. I lightly blipped the throttle and instantly saw 40psi. When parking in the garage I could hear the alarm again and saw 7/8 psi. Switched off, then keyed on 5mins later and noted the water temp had risen to 226degF. Fired it up to circulate the water and the oil pressure read zero so switched off. Plugged in efilive and restarted which confirmed both GM and Spa sensors were reading zero oil pressure. No change to engine running or noise btw.
Left to cool some more and pulled the oil filter off. On crank only (pulled fuse on the RLTC) there was no oil flow so called it a day.
On return have found the below info on the net. Seems likely given my experience. Since putting the car on the road I have occasionally noticed a low blip in oil pressure at low rpm. Typically when coming off load, but oil pressure returns when revs are increased or clutch is pressed. Anyone got any experience of this or suggestions. My current plan is to fit a new stock GM pump and check for any contamination in the oil.
http://www.camaro5.com/forums/showthread.php?t=72458PIP4158C: Low Oil Pressure Due To Seized Oil Pressure Relief Valve - (Dec 29, 2009)
Subject: Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve
Models: 2008-2009 Buick Lacrosse, Allure (Canada Only)
2007-2010 Cadillac CTS-V, Escalade
2007-2010 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
2007-2008 Chevrolet Monte Carlo SS
2007-2009 Chevrolet Impala SS, Trail Blazer
2009-2010 Chevrolet Colorado
2010 Chevrolet Camaro
2007-2010 GMC Envoy, Sierra, Yukon
2009-2010 GMC Canyon
2008-2010 Hummer H2
2008-2010 H3 Alpha
2008 Pontiac Grand Prix GXP
2008-2010 Pontiac G8 GT
2007-2009 Saab 97x
with the Following Aluminum V8 Engine RPOs:
L76, L77, L92, L94, L99, L9H, LC9, LH6, LH8, LH9, LS2, LS3, LS4, LS7, LS9, LSA, LZ1
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may complain of low oil pressure, no oil pressure, and/or engine noise, which may be the result of a sticking oil pump pressure relief valve. In some instances, this may occur intermittently if the valve frees up when the engine cools down.
Recommendation/Instructions:
If SI diagnosis isolates low mechanical oil pressure at the oil filter housing and oil pressure sensor, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern.
Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
