May 03, 2024, 01:40:55 PM
Author Topic: FS: '93 Silver/Blk RX7 FD w/built LS1/T-56 *SOLD*  (Read 3780 times)
BenR
  • Guest
« on: July 19, 2010, 03:39:02 PM »
Silver w/black leather interior
Clean title, no leans, no accidents
Current mileage:
Chassis 98K
LS1 shortblock 88K
LS1 top-end build (heads, cam, oil pump, etc.) 28K
Rebuilt tranny 12K
Clutch/flywheel/TOB/Slave 10K
The body, wheels, brakes, suspension, interior and everything else on the car is bone stock. It was originally an automatic so it has the 3.90 diff.
The conversion itself was done by Hinson Supercars as a complete turn-key swap. The A/C, cruise control, power steering,
ABS etc. were retained and work perfectly, as do all the factory gauges and electrics.
Hinson originally dynoed the car at 429rwhp/408rwtq but I have since had it retuned locally for 91 octane and to improve the low-speed drivability
so I would expect the peak power is down a bit from those numbers.
Factory subwoofer, undertray and driving lights have been removed from the car but will be included along with an extra pair of factory rims.
This car does not have a BAR sticker; Please PM me for smog-related questions
Mods:
AFR 205 heads w/spring upgrade
ARP head studs
Comp 224/230 112 cam
Comp chromoly pushrods (stock length)
ported stock TB
SLP blueprinted LS6 oil pump
Rollmaster billet timing set
ASP underdrive pulleys
Katech billet belt tensioner
LS6 PCV conversion
Hinson 3.5" Cold Air Intake
Hinson 1-7/8" mid-length headers
Dual PowerCat 3" high-flow convertors
Hinson Y-Pipe dual 3" to single 3.5"
Hinson 3.5" welded single exhaust w/Flowmaster Hushpower 3.5" Muffler
Optima battery relocated to passenger side bin
Hinson fuel system (Walbro pump, Aeromotive billet filter, AN fuel lines & fittings)
Hinson cooling system
Sound deadener/heat shield on trans tunnel
Custom PCM tune by Mark Romans
Heidt's billet power steering valve/adjustable assist
LS7 clutch & flywheel
Rebuilt T-56 with a steel 3-4 shift fork, carbon blockers and all new bearings, synchros and seals
Urethane motor mounts
Mazdaspeed diff bushings
*SOLD*  Thank-you everyone for the kind comments.
More Pics:
« Last Edit: August 17, 2010, 11:02:01 AM by BenR »
Offline GEAUX FAST
Re: FS: '93 Silver/Blk RX7 FD w/built LS1/T-56
« Reply #1 on: July 19, 2010, 07:43:33 PM »
located???
Offline jcm0791
« Reply #2 on: July 20, 2010, 04:09:47 AM »
PM'd
And I am guessing California going by the BAR comment ... though I am prepared to be corrected.
Offline mdpalmer
« Reply #3 on: July 20, 2010, 08:16:42 AM »
Sounds like a CA car. Man that thing is pretty.
Mike
My Build Thread
YouTube Vids
Offline GEAUX FAST
« Reply #4 on: July 20, 2010, 10:35:55 AM »
I wish I could find another five grand in my toy budget this thing is perfect...
BenR
  • Guest
« Reply #5 on: July 20, 2010, 11:04:37 AM »
located???
D'oh!   :-[   Sorry, location is Sacramento, CA
Offline BAD-LSX-7
  • Back in Action for 2012
« Reply #6 on: July 20, 2010, 11:06:02 AM »
nice looking car! i always wanted a silver or white one!
>:( >:(2012>:( >:(
Offline GEAUX FAST
« Reply #7 on: July 20, 2010, 08:25:46 PM »
if it comes down to a fire sale I think i can afford it !!
Offline 6ta1
« Reply #8 on: July 23, 2010, 07:41:24 AM »
pretty nice indeed
