Not looking to build, car is a TII model, just looking at what the limits are and where I can safely go. I plan on doing some autox and drag racing, but mostly enjoying the car for the summer, don't what to blow it up. I guess I will be researching a solid axle or Thunderbird IRS setup soon!
I hate to say it , but most of that info is gone for now. The T2 is strong enough for some racing. I got over 300 passes on mine with a stock LS1/4L60E. The T56 will destroy a T2 quite quickly with about 400HP depending on driver skills in drag racing, however, careful launching and avoiding the wheel spin/hop it will be plenty good for a long time.
Some 8.8 irs info: The Tbird super coupe is a 28 spline CV axle output, as well as the 1999/2002 mustang, the big difference in those 2 cars is the mustang is an aluminum cased diff. 2003/2004 Cobra diff is 31 spline axle outputs and is also aluminum cased. Ford explorer diff is 31 spline and is also aluminum cased diff, but the housing is designed a bit different then the previous 3. Inner CV tripods are interchangable on all versions. They have different external CV design but the tulip cups are made the same. Ring and pinions I beleive are the same throughout all the diff's but the bearing kits dont share the same seals between the 31 and 28 spline versions.
At this point thats all I can remember, must be getting old or something!
