Difference between the N/A Diff and the T2 diff on a fc
by
FCs Rule
on 23 May, 2010 00:08
#1
by
andrewb70
on 23 May, 2010 01:43
Those measurements in millimeters are off, or maybe they just need a decimal point somewhere. 1000mm = 1m = about 39 inches.
Andrew
#2
by
mattster03
on 27 Jun, 2010 15:33
can someone confirm the following:
1986-1988 TII diff = clutch type
1989-1991 TII diff = torsion
#3
by
mpcv2000
on 27 Jun, 2010 21:50
I have a 89 Turbo II and if I'm not mistaking the rear end ( differential ) unlocked on me a few times , is it possible ?
I'm used to clutch type diff. so we can rebuilt them but looks like the 89-91 is different. Can I have it rebuilted ?
If not , can I swap a 86-88 Clutch type in it and keep my gears ?
#4
by
digitalsolo
on 27 Jun, 2010 21:56
Confirmed.
#5
by
RXTC
on 27 Jun, 2010 22:01
you can swap the pig, and be done with it.
Confirmed.
Second that confirmation.
#6
by
bikedad
on 28 Jun, 2010 00:18
From what I understand about the TII diffs are:
S4 has equal length stub shafts
S5 has unequal length stub shafts
If you pop them out you should be able to differentiate between them.
86-88 (S4) is clutch type
89-91 (S5) is torsion
#7
by
mpcv2000
on 28 Jun, 2010 12:56
That means if I swap a S4 differential in my 89 Turbo II I will need to find S4 Stub shaft too ?
I'm writing down my shopping list.
#8
by
digitalsolo
on 28 Jun, 2010 13:00
Handy picture:
#9
by
jim3
on 29 Jun, 2010 03:10
Thank you Shaun and Blake. A little more and this should be made a sticky.
#10
by
mattster03
on 03 Jul, 2010 20:08
Thanks for the confirmation guys... I'm going to head down to pick up my '88 TII diff this weekend... $150
#11
by
FCs Rule
on 04 Jul, 2010 12:57
well to isn't it 87 88 t2 and then 89-92? there are some rare 92s out there
#12
by
383mazda
on 29 Jul, 2010 20:34
Is there way to tell from the outside what year TII rear you have? If not which is the easier way to tell, pop the diff cover off and look inside or pull the stub shafts out and measure them (p.s. I have never peaked into or taken apart a diff, I just know I have a TII diff in my garage with matching axles... but I don't know if it's the clutch style or not)
#13
by
josh18_2k
on 29 Jul, 2010 21:04
S5 diffs are viscous. US FC's never got the torsen, but apparently JDM efini's did. FD diffs are all torsen.
#14
by
Speedfab
on 25 Aug, 2010 11:14
TorSEN people, torSEN
Torsion - the twisting of an object by an applied force/torque
Torsen - short for TORque SENsing differential
