Tools:
philips/flat screwdriver
oven
dremel with sanding drums and cutoff wheel
Materials:
aftermarket housing
morimoto d2s projector
d2s bulbs (oem or morimoto)
ballast
e55 shrouds
projector/bulbs/ballast/shrouds can be purchased at
theretrofitsource.comStep1. Removing lens
Preheat your oven to 200f, then take a baking sheet cover it with foil and place your headlight housing on it and place it in the oven. Set you timer for 10 minutes and watch your housing carefully. DO NOT WALK AWAY, since every oven is different it may take a longer/shorter time to remove the lens.
Take the headlight out and stick a small flat head screwdriver between the lens and housing and twist slowly. Do this all the way around until you can get your fingers behind the lens and Slowy pull it off. IF the glue starts to harden again simply put it in the oven for a few minutes and try again.
You should end up having something like this.
Step 2. Modify housing
This is where you break out the dremel. you have the housing looking like this at first.
You want to cut and sand until it looks like this.
Here are the cuts made in red.
Now for the inside. Sand up into the housing, this is so the projector can be angle up to fit the shroud. You should end up with it looking like this.
Step 3. Bolt in projector
Insert projector from front side, place bracket on the back of the projector then screw the nut on. Pretty self explainatory.
Step 4. Adjusting rotational cutoff.
After everything is all bolted up you have to run your relay harnes and mount your ballast to your car. When your finished mount your lights to your car plug your bulbs in and turn on your HID's. You will notice your cutoff isn't horizontal. To fix this you have have to twist the projector until you get your cutoff adjusted.
Next make reference marks as i did in the above photo just in case they move out of adjustment.
Step 5. Mount your shrouds
This step is pretty simple. First mount your shroud to test fit it you may have to sand the inside edge a little bit for it to fit. You may have to move the projector up/down to fit it into the middle of the shroud ,the projector has a some wiggle room since there is a rubber mount on the back of it.
When everything looks fine remove shroud and apply glue between the shroud and projector and push it on. I would let it dry over night after completing this step. This is what you should have so far.
Step 6. Replacing lens
Now your project is almost complete. Simply follow the same steps as removing the lens. First place lens on the housing and gently push on it so it stays. Preheat oven to 200 then place your headlight in it but make sure you take out your bulbs before you do. After about ten minutes take out your lights and push on the lens firmly until it is fully seated into the housing. You can now put on the clips and screws back on.
CONGRATS! YOU ARE NOW FINISHED!
