That is a very clean solution sir. That is the highest praise I give ... well, until I copy your design ...then we will be into the "imitation is the sincerest form or flattery" range
I would like to relate a little tale:
When I bought my car (already LS1 converted) it was obviously also converted from auto to manual transmission. The car suffered from a low brake pedal ... not soft, just low. I found that when they installed the new pedal box they did not adjust the master cylinder pushrod length and a little extra free play there makes a big difference in pedal height. The factory spec for free play is quite a wide range here so I was a little surprised as to how much difference it made (more than an inch of pedal height at full service pressure for a fairly small adjustment) Yes, yes ... I realize that we are dealing with a motion ratio and such .. I was still a little surprised.
Being that the master cylinder is on the same plane as the push rod, any reduction in movement should transfer into a better pedal (higher, firmer, and more consistent)
