I finally have another batch of FD Hood Strut/Damper Kits up for sale and ready for shipment. This is following up on the group buy I did around this time last year that was very well-received and produced many happy customers. If you care to read up on the last group buy, you can find it here:
http://www.norotors.com/index.php?topic=18136As many of you know, the factory hood prop rod is often lost to make room for radiator and intake setups on V8-swapped FD's. There are a handful of kits on the market which use Gas Struts to assist in opening/closing the hood as well as propping it in an open position thus fully replacing the factory prop rod. Unfortunately, the majority of the kits use a "cheap" design for the hood bracket which only captures one of the two hinge studs leaving a design that tends to twist and cause headaches for the end user. The high quality option on the market which captures both studs is very expensive and is not currently available (as far as I can tell).
Payment Info:If you are interested in purchasing a set, please visit my website which accepts Paypal and Credit Card.
http://www.secondboltracing.comI have kits in stock and ready to go.
The kit which I am selling includes:
-LH & RH Hood brackets machined from high quality aluminum
-(2) top quality dampers which are properly sized for the stock hood application
-All necessary hardware for a clean install
Here is a video of the Dampers in action:
