Well, it's about time I put up a build thread. You could say things are.....getting a bit serious around the garage.
This car was formally owned by "HTH3r0" and "Arkady" on here. I acquired the car earlier last year with the LS1 swap already in it. Once spring and summer rolled around the corner, I took it to the track and ran into a few issues. Obviously, I couldn't keep the thing from breaking. So I put in a Ford 8.8 rear end and started breaking stockish axles every time I went to the track - the joy of launching on a drag radial!
Since then, I've "woken up" the car a bit with a set of 243 heads, custom cam, and nitrous.
What are my goals? To basically have a super light street car to have fun with on and off of the street.
I would also like to see low 10.XX passes @ 130 on motor. Who knows on nitrous. I guess we will find out.
Motor 2002 FBody LS1 with 33k miles - tucked harness
Brett "Landspeed" Stage 3 243's
Custom grind COMP cam for all motor / nitrous
Nitrous Outlet 78mm Plate Kit
GFO Racing Intake
LS6 Intake Manifold
Ported LS6 TB
ATI Damper
PSC Power Steering Kit
JTR 1 7/8 Calico coated headers into 4" Vibrant midpipe with QTP electronic cutout with dash mounted switch to 3" HKS Carbon Ti mufflers
42# Injectors
Automotive 340 Stealth
Hinson Supercars engine mount kit
C5Z Engine Covers
DrivetrainT56, 13k miles since rebuild
Monster Stage 3 Clutch
Pro 5.0 Shifter
Ronin 8.8 IRS Rear Differential Kit
Ford 8.8 IRS - Ford Performance GT500 internals
3.73 Gears
Driveshaft Shop Complete Pro-Level Axle/Hub Kit
Suspension & Wheels5zigen FN-01 17x8 - Front, 17x10 - Rear, polished finish
225 Michelin Pilot Super Sports - Front
275 Mickey Thompson ET Streets - Rear
Energy Suspension bushings
Battle Version adjustable toe links
Supernow camber link
Adjustable camber links
Tokico blue front struts
KYB AGX rear struts
Tanabe GF210 springs
Racing Beat strut tops
Exterior Painted Porsche Guards Red
ShineAuto carbon front lip
ShineAuto carbon side skirts
ShineAuto carbon rear diffuser
Aerocatch carbon hood pins
Turbo2 hood
Turbo2 wing
Clear FTP lenses
HID headlights
InteriorBlack Turbo2 seats
Custom gauge cluster
Suede door cards
Suede headliner
Suede armrest
Suede shift boot
Personal steering wheel
NRG Quick Release
Flossy weighted shift knob
Interior is herculined, dynomat'd and boom mat'd
On the Dyno after a few months of having the car.
Here's a video of a dyno pull. Car made 390/389.
http://vid110.photobucket.com/albums/n110/liqale/RX7%20Project/video0001_02_zpsbxququpg.mp4Passes on the old TII rear end. Pretty consistent.
Then the stock TII rear end went boom. And this happened.
Ronin 8.8 kit.
Grinding down the 8.8 to make it fit at Fathouse Fabrications. Thanks to Eric for the fresh rebuild with nice internals.
Big brother, little brother.
8.8 is in!
Then a new PB happened shortly after.
...and then this happened shortly after.
Fixed the axle in time for the annual SNS NoRotors meet. Decided to officially weigh the car. She's pretty heavy!
Cleaned up before winter rolled in.
Here's one of the 243's before being sent off to Brett @ LandSpeed.
