Normal temp of LS1
by
fosingwo
on 30 Jun, 2010 19:21
What temps are you ls1 running. After like 25 min of driving my ls1 goes up to 180-200 and this is normal local driving shifting usually before 3k rpm. is this normal?
#1
by
Tibbys96Z
on 30 Jun, 2010 20:03
Yep normal
#2
by
Pez
on 30 Jun, 2010 20:13
a little lower than OEM settings.
#3
by
darkhorse
on 30 Jun, 2010 20:23
depends what thermostat you're running and fan turn on/off temps.
once my stock thermostat opens at 194*-195*, it (obviously) does not drop below. it can, however, get up to 220*-230* before the fan kicks on. these are normal operating temperatures (195*-230*) for a stock LS1.
#4
by
nemesis
on 30 Jun, 2010 20:24
I've been operating up in the 220* range and have had some concern. Is this really within the normal operating range? I was thinking I still had some air in the system.
#5
by
Pez
on 30 Jun, 2010 20:30
OEM low fan turn on temp is 226 and high fan is 235.
#6
by
darkhorse
on 30 Jun, 2010 20:34
+1
220* is fine IMO. GM lets the motor get to these levels for thermal efficiency (gas mileage) and reduced emissions.
#7
by
spacevomit
on 30 Jun, 2010 22:21
+1
But keep in mind, manufacturers nowadays are basically sacrificing everything else (like wear) in the name of mpg and emissions. That is impression I got from an article I read, anyway (It was about manufacturers specifying low viscosity oils, because it allows them to meet federal fuel economy standards. The author of this article actually speculated that total fuel economy over the life of the engine would be lower due to wear). Not that I know what configuration will yield superior wear characteristics...
#8
by
fosingwo
on 01 Jul, 2010 14:53
I dont think my fan even comes on. havent really check but I know the fan comes on when I turn the car off and it stays on for a few minutes.
and thanx guys for clearing that up. I was concern that I was overheating. and the hood gets so hot you can probably fry an egg on it lol
#9
by
wickedrx7
on 01 Jul, 2010 15:01
Most people change there fan setting to 210 when they program their PCM. 195 -210 is perfect IMO. I think people who run 160 thermos are too low and there is no benefit. To each is own.
#10
by
lsxrx7
on 01 Jul, 2010 15:03
i keep mine at 195* all the time,
fan comes on at 200* and lower it back to 195 in matter of seconds
#11
by
zbrown
on 01 Jul, 2010 18:11
But keep in mind, manufacturers nowadays are basically sacrificing everything else (like wear)........
I'd rather have an engine running at 220 than 160 as far as wear is concerned, especially important to have the oil temps up in the operating range compared to low
#12
by
darkhorse
on 01 Jul, 2010 18:37
ditto.
not saying the engine wear claim is right and i'm not saying is wrong... but, i will say this; extraordinary claims require extraordinary evidence.
#13
by
nemesis
on 01 Jul, 2010 22:21
So what should I set the high limit alert on my gauge to? 235*? 240*?
#14
by
spacevomit
on 01 Jul, 2010 22:36
Well, I''m not actually making a claim, I'm just saying I got that impression from an article. However, even if I were to speculate, I would never suggest that 160f was ideal for wear (although I wouldn't be surprised if wear was decreased at, say, 10 degrees less than the temp. at which emissions/mpg are best (this number is totally baseless though)), because the oil film is dependent on a certain internal clearances, in other words expansion from heat. I don't know what that temperature is, or how much crankshaft journal clearances tighten up with heat, but I think the pistons expand in the cylinder bores quite a bit.
Does it really seem likely that long term wear, emissions, and fuel economy, are all best at the exact same water temp?
