March 05, 2021, 11:29:21 AM
Author Topic: Tuned my Turbo F-body on pump gas . results  (Read 5233 times)
Offline project dc2
« on: September 02, 2011, 04:31:08 PM »
lil bit of FML moment when i got back in town
80 lb injectors  -6AN feed line  walbro feeding a 044 pump ( need a bigger fuel line and more pump/injector
COAN TH400 on a simple LQ4 build
turbo of course =)
did a 790 WHP hit but turned the boost down due to high injector duty cycle.
im happy =)  its making the same power as before but on less boost due to TFS heads.
Offline BeasTT
  • Twinz for teh winz
Re: Tuned my Turbo F-body on pump gas . results
« Reply #1 on: September 02, 2011, 04:34:21 PM »
Details?
Nick Shultz
1993 Rx-7
Offline project dc2
« Reply #2 on: September 03, 2011, 03:47:43 PM »
Details?
LQ4 370 Block- balanced blueprinted
Wiseco 4.030 Bore 8.7:1 Compression pistons
Eagle rods
Stock crank
Clevite rod. main. and cam bearings
LS2 timing chain kit from ls1tech sponsor Yank
Same newtech performance comp cam shaft
TFS 225CNC heads
coan TH400 FMVB
Pro torque converter 3200 stall
Moser 9" rear end from LS1tech sponsor JAWSGEAR
 single walbro in-tank feeding a Bosch 044 fuel pump with -8 Feed line to the rails and a fuel lab regulator 80 lb injecotrs
New Spoolin Crossover for T4 based turbo + single 44mm gate outlet
GT4580R
 on pump 91 octane gas with methanol injection*
Offline mpcv2000
« Reply #3 on: September 03, 2011, 07:15:27 PM »
 :o
Martin !
« Reply #4 on: September 03, 2011, 08:25:58 PM »
boost? timing?
Offline project dc2
« Reply #5 on: September 11, 2011, 01:24:10 AM »
13.87 psi. 91 pump gas. timing unknown. tuned and locked by the tuner =)
Offline Oliver
« Reply #6 on: September 11, 2011, 07:58:12 AM »
Good numbers.
BLNTB
« Reply #7 on: September 23, 2011, 03:50:28 PM »
you should put some e85 in there and see what it can really do :)
I have a crazy 1700hp Aeromotive pump with pre/post filter setup for sale.  $700
Offline project dc2
« Reply #8 on: September 24, 2011, 10:05:07 PM »
yeah ... the gas mileage is already in the single digits i'd hate to see what it'd be with E85 !!!
« Reply #9 on: September 24, 2011, 10:06:43 PM »
Single digit?    OUCH.
Offline Speedfab
« Reply #10 on: September 25, 2011, 12:10:33 AM »
Well, at least now we know why your "tuner" locked it...  He didn't want anyone to know he's a dumbass.  Any monkey can target an air fuel ratio and move the timing until they get max power.  The ability to get good drivability and fuel efficiency is another matter entirely.  As someone who has done this for 30 years, I recommend you get a new tuner.
Not bagging on you at all, don't take this the wrong way.  Car looks great and runs strong.
Offline project dc2
« Reply #11 on: September 26, 2011, 11:58:56 AM »
Single digit?    OUCH.
prob 9 -11 mpg on the city streets . i rarely ever drive it on fwy  just because i dont take it very far.    another thing to mention is that my MPH is not entirely accurate because im going off the front wheel ABS sensor for a reference point with a  mathematical equation to figure out what number ratio in input into HP tuners.   My supra on E85 gets about 13 MPG on  E85 with 750 wheel.  i already experience E85 and the type of gas mileage. put a V8 on that and i'd hate to imagine what it'd be like.  my supras been street and dyno tuned by Johnreedracing.  tuner of underground racing TT lambos, hennsey racing cars, Virtual works supra etc.  very very very good tuner.
my camaro is tuned by a local company though.
Offline ablake211
« Reply #12 on: September 26, 2011, 12:05:01 PM »
I spent a TON of time on my drivability tune. When I first started I was getting around 9mpg on my setup which I mostly drive city as well. I am getting 13-15 now and I mostly just drive around town here and do pulls. I want to do a hy tank of gas to dial that in perfect and see what kind of mpg it gets.
« Reply #13 on: September 26, 2011, 12:49:03 PM »
Interesting.   I got about 18 mpg city and 28 mpg highway with my car on gasoline.   That was with a stalled automatic too.
I see around 13 city and 20 highway with it on E85 now.   Similar power output.  I do have 3.07 gears and a lockup converter though.
Offline ablake211
« Reply #14 on: September 26, 2011, 04:32:04 PM »
Judging my MPG is really hard since I don't ever just cruise my car. When it comes out it is getting beaten and that is it really.
« Last Edit: September 26, 2011, 06:29:13 PM by ablake211 »
