August 21, 2019, 05:03:32 AM
Author Topic: L33 T-56 8.8 swap 1980 RX-7 SA22C  (Read 44513 times)
Offline dream36realms
Re: LSx T56 swap into First Gen RX7 SA
« Reply #15 on: July 14, 2011, 03:05:57 PM »
I hear ya man. I once bought a car that never ran and it pissed me off. I am fortunate that mine was fully restored when I picked it up hence the huge price tag. I beat the crap out of the 12a over the two weeks I was home. Now I just want to get to it and get started on it. I picked up the tranny brace from grannies to get a basic point of reference for level after I get the motor mounts fabbed, I will make another tranny brace that more fits my needs (2 pipes into 3" back). Problem I am going to have is fitting it all with the torque arm kit.
For wheels I would recommend calling rota up and finding something. They make custom offsets and bolt patterns for whatever you pick out.
日までに仕事および夜までに虐殺。
を下って、人類と
Offline SSjon
« Reply #16 on: August 12, 2011, 07:49:29 PM »
This project has been on the back burner for the past month, I have been doing little things along the way. I routed the PCM connectors under the dash and I have half of the fuse block wiring ready for a fuse block. I sent my Aluminum radiator back to the shop to get the mounting brackets I need  redone, he is a good welder but not the best at understanding directions. I am also using the truck intake, water pump, and crank pulley. With that I made my own Alternator mounting and idler pulley. My block came with the lower hole already threaded for some reason, lucky me.
So here is the shopping list as it sits
Better Headers, full exhaust back
LS1 intake, Water pump, Crank pulley
Driveshaft and conversion flange....
Ford 8.8 with all the conversion brackets and Limited slip (maybe)
Radiator hoses
Throttle Cable
Install Clutch Master cyl (I need to cut a 1 3/8" hole in the firewall for this)
L33 T56 8.8
« Reply #17 on: August 12, 2011, 09:18:49 PM »
getting there man. good job
日までに仕事および夜までに虐殺。
を下って、人類と
Offline SSjon
« Reply #18 on: August 14, 2011, 01:50:34 PM »
Yesterday I had some more progress, and it felt good!
I found a sweet deal on a 1 3/8" multistep drill bit to make the clutch master hole larger, 12.99 on sale! Beats $40 that Macs wants for a reconditioned drill bit. So I drilled and installed the New Tilton 13/16" Master Cylinder, bleed it, and bleed the clutch with the help of my friend. Only slight modification to the lip on the firewall to clear the big reservoir, the stock bolt holes lined up nicely, and the stock pedal bracket threaded right on.
After that I flipped my idler bracket around for shorter belt routing and more room for an air intake later, cut and measured out for a serp belt that I will pick up today.
I found out that I can unbolt the front sway bar and link bar bracket so I can drop it down to get the radiator in. The lower radiator hose connection is a PITA right were the sway bar sits. Pics to come of radiator install after it is done at the aluminum welding shop again.
L33 T56 8.8
Offline SSjon
« Reply #19 on: August 14, 2011, 07:34:32 PM »
Some pics from this weekend
Old and new
Installed and a look at my wiring mess to become a fuse box
Accessory Drive done
L33 T56 8.8
« Reply #20 on: August 14, 2011, 07:53:31 PM »
what are y9u doing for brakes? I am using the turbo 2 brake setup but havent figured out what to do for MC and booster :(
日までに仕事および夜までに虐殺。
を下って、人類と
Offline SSjon
« Reply #21 on: August 14, 2011, 08:14:10 PM »
Stock brakes until I swap the rear end and front brakes. I need to get a feel for this car in stock form plus 200 hp, then I will work on the suspension.
L33 T56 8.8
Offline WannaBeFast
  • Single and Looking
« Reply #22 on: August 14, 2011, 09:11:58 PM »
Hey this looks really good so far. I like all the fab work. Keep it up.
Offline FCs Rule
« Reply #23 on: August 15, 2011, 09:03:16 AM »
looking good man!
._________________________
Offline SSjon
« Reply #24 on: August 15, 2011, 01:23:53 PM »
thanks for the support guys, this project is fun, but I cant wait to get to the point where i can  :drive: it! haha
L33 T56 8.8
Offline Burntz
  • Just trying to ball on a budget
« Reply #25 on: August 15, 2011, 01:39:08 PM »
I just finished my 8.8 SA swap. Really wasn't all that terribly hard. Check out my Project SleepR build thread for info. I'm confident you could do it on your own :)
Offline thetastelingers
  • Rotors are for brakes
« Reply #26 on: August 15, 2011, 03:23:49 PM »
And I thought the FD was a light car to swap.
This thing is going to be insane.
wazzaaaaaaaaaaaapppppp!
Offline SSjon
« Reply #27 on: September 19, 2011, 09:28:59 PM »
Progress! well sorta lol
I finally got the radiator mounted, along with a fan. I put together some radiator hoses just to get the job done until I get a LS3 or L99 water pump.
I picked up a fuse box, and I'm still working of the wiring.
and I picked up a nice new jack, smooth and fast lifting
L33 T56 8.8
Offline SSjon
« Reply #28 on: September 27, 2011, 10:00:32 PM »
I finally got around to finishing my wiring, rigged up a fuse box, and re-purposed some stock relays. My friend picked up a starter for me today so I decided to give it a crank. It fired right away but did not run, damn security systems! I need to find a tuner around here or break down and send it off for a tune.  On a side note, pretty cool that flames shoot out of open headers!
L33 T56 8.8
« Reply #29 on: September 27, 2011, 10:37:30 PM »
looks good man! you need to get this done and bring it out to the last street legal
