A quick introduction. I'm Mark aka "gnx7" on the forums and NorCal Motorsport is my company! Been involved with RX-7 engine swaps before there was even a forum for them. Did a couple Buick Grand National (turbo V6) powered FC RX-7's in the late 90's and then moved on to a heads/cam 440rwhp LS1 powered FD RX-7. The car ultimately competed in the Sports Compact Car Magazine's 2005 "Ultimate Street Car Challenge" where it won the handling competition pulling a 1.09g average on Michelin Pilot Sport Cup tires (1.13g peak). Latest conversion is another FD running a dry sump LS7 with lots of other mods. I am very familiar with the LSx engine and RX-7 swaps.
Current products:
T56 Magnum TUET11009
If you want the ultimate T56 we also sell the new T56 Magnum which is essentially a customized TR6060 for hot rod swaps. Everything about it is superior to the older '93-02 style T56's. With parts availability being an issue on the older T56's and simply an outdated notchy shifting transmission..... the new Magnum surpasses that offering easily with smooth modern shifting and ability to easily hold 1000rwhp+. Please see the link in my vendor section for an explanation on this great transmission. $3095 MSRP PM me for forum pricing and more info. I run one in my car and it shifts like butter.
We also stock parts related to swapping in a T56 like pilot bearings, slave cylinders, billet offset shifters, bolt kits, bellhousings, etc.
McLeod clutches and related parts:
single disc 500hp rating
RST twin disc 800hp rating
RXT twin disc 1000hp rating
RXT twin disc HD 1200hp rating (used in our 1200rwhp+ turbo LS9 FD swap. Great pedal feel. We run a stock T56 Magnum!)
aluminum and steel SFI rated flywheels, ARP bolts
LS7 clutches also for budget builds and Fidanza alum flywheels
T56 rebuild service:
includes full R&R of your LT1 or LS1 FBody T56. We install new steel 3/4 shift fork vs. the flimsy stock alum piece, HD carbon blocker rings, synchro rebuild kit, new bearings, bronze 1-4 fork pads, and new seals. Only factory Tremec parts are used in our rebuild procedure. My transmission expert has been in the industry for 30+ years and knows T56's! A rebuild in this form should be capable of handling 700hp+. Additional parts/upgrades will be added to the cost (ie broken gears/input shaft/counter shaft, etc). Add $99 for billet keys. Replaces the stock plastic replacements and a good idea for any hard driven T56 setup...
$1500
LSx stock and performance parts:
Complete pullout engines from stock to fully modified and built from the bare block up! Small inventory on hand
Misc. used engine parts: blocks, cams, heads, intakes, ported TB, engine harnesses etc.
3 LSA longblocks currently in stock needing rebuild..... as of 7/25/16
Holley Performance products and MSD Atomic intakes
Holley EFI HP/Dominator, 103mm TB, Hi Ram intakes, MSD Atomic intakes, all Holley products they make!
Custom intake porting for Atomic intake also available! Add $250
BrianTooleyRacing.com
We sell all Brian Tooley Racing products and anything on their website: valvesprings, pushrods, Morel link bar lifters, cams, blocks, heads, rockers, crankshafts, rods, pistons, custom cylinder head porting services etc
****We also sell Cammotion custom solid and hydraulic roller cams and related parts for high end builds.
Ohlins DFV and Penske coilovers
from entry level to double/triple adj coilovers..... custom valved Penskes of course!
Speedhut gauges
All Speedhut gauges for sale. We do not do bezel modifying/reshaping.
Walbro and AEM fuel pumps
Walbro fuel pumps.... 450lph/400lph/255lph.... all Walbro pumps and AEM pumps also!
Best way to reach us:
norcalmotorsport@gmail.com
* I do my best to return messages/emails within 24hrs either via email or telephone. Thank you!
415.260.8768 cell 8am-6pm PST calls only please
