Ok, I know the relay up front labeled Fuel Pump is for the speed portion of the circuit. So if I want it to provide the full 12+V at idle and low cruising speeds - can I remove this? In the end, I plan to put a relay in the back that bypasses all this and only uses the fuel pump voltage as a signal, not as power. If I kill that circuit will it kill the overall power to the pump? I don't think so, but needed to make sure. My idea is at the end.
Let me see if I can find a diagram....
The circuit,(with the wire mod done to bypass the power going through the ignition switch), idling/cruising:
Speed circuit enabled, i.e. WOT and fast:
It seems to me by reading the schematic - that if the relay is missing or is open, then it goes to the resistor - which drops the voltage by ~3v. So if I just butt connect the L/R to the W/R wire, it acts like full speed all the time? I can't find the color legend - what are those two colors? I assume something with red - just not sure what. I'm going to assume they are the big gauge,(10), wires that are white and blue with red stripes. That would make the most sense since its sending power to the fuel pump.
Any thoughts?
BTW, I didn't really want to get into that front harness - but with Samberg's radiator, there isn't much choice... Its not that hard, but you do have to take your time.
