August 06, 2020, 09:54:51 AM
Author Topic: ?? Rotating Assembly Sale! - Callies, K1, Diamond ??  (Read 2683 times)
Offline Hinson Motorsports
  • Pre-Staging
  • Engine Conversion and LSx Specialists
    • Hinson Motorsports
« on: May 20, 2010, 10:10:18 AM »
Callies, K1, and Diamond are at the top of the industry for quality of finish and reliability. These premium made engine components have been proven to last under our testing in very high horsepower applications.
FREE SHIPPING on any complete rotating assembly purchase! Feel free to contact us with any questions. You can reach us at 205-267-6387 or seth@hinsonsupercars.com
Common Packages
Includes Crankshaft, Rods, Pistons, Rings
Starting at $2090 - 383ci LS1 Rotating Assembly
Starting at $2115 - 402ci LS2 Rotating Assembly
Starting at $2090 - 416ci LS3 Rotating Assembly
Starting at $2185 - 428ci LS7 Rotating Assembly
Starting at $2455 - 454ci LSX Rotating Assembly
Crankshafts
$795 - Callies Compstar 4.000" Crankshaft
$935 - Callies Compstar 4.100" Crankshaft
$935 - Callies Compstar 4.125" Crankshaft
$755 - K1 Technology 4.000" Crankshaft
$755 - K1 Technology 4.100" Crankshaft
$755 - K1 Technology 4.125" Crankshaft
Connecting Rods
$525 - Callies Compstar 6.125" Connecting Rods (H-Beam)
$750 - Callies Compstar 6.125" Connecting Rods (I-Beam)
$525 - K1 Technology 6.125" Connecting Rods (H-Beam)
Pistons
2618 Forging
$635 - Diamond LS1 5.7L Street/Strip Flat Top Pistons (-2.0cc - 0.0cc)
3.905" Bore, 3.622" Stroke, 6.098" Rod
3.905" Bore, 3.622" Stroke, 6.125" Rod
3.905" Bore, 4.000" Stroke, 6.125" Rod
$635-660 - Diamond LS1 6.0L Street/Strip Flat Top Pistons (-2.0cc)
4.030" Bore, 3.622" Stroke, 6.098" Rod
4.060" Bore, 3.622" Stroke, 6.098" Rod
4.030" Bore, 3.622" Stroke, 6.125" Rod
4.060" Bore, 3.622" Stroke, 6.125" Rod
4.000" Bore, 4.000" Stroke, 6.125" Rod
4.030" Bore, 4.000" Stroke, 6.125" Rod
4.060" Bore, 4.000" Stroke, 6.125" Rod
$660 - Diamond LS2 6.0L Street/Strip Flat Top Pistons (-2.0cc)
4.005" Bore, 4.000" Stroke, 6.125" Rod
$635-660 - Diamond LS3/L92 Street/Strip Flat Top Pistons (-2.0cc)
4.005" Bore, 3.622" Stroke, 6.125" Rod
4.065" Bore, 3.622" Stroke, 6.125" Rod
4.065" Bore, 4.000" Stroke, 6.125" Rod
4.070" Bore, 3.622" Stroke, 6.125" Rod
4.070" Bore, 4.000" Stroke, 6.125" Rod
4.125" Bore, 4.000" Stroke, 6.125" Rod
4.130" Bore, 4.000" Stroke, 6.125" Rod
$730 - Diamond LS7 7.0L Street/Strip Flat Top Pistons (-3.84cc)
4.125" Bore, 4.000" Stroke, 6.077" Rod
4.130" Bore, 4.000" Stroke, 6.077" Rod
$830 - Diamond LS1 5.7L Inboard Forging Race Flat Top Pistons (-2.0cc)
$830 - Diamond LS1 6.0L Inboard Forging Race Flat Top Pistons (-2.0cc)
$830 - Diamond Resleeved LS1 Inboard Forging Race Flat Top Pistons (-2.0cc)
$680 - Diamond LS1 5.7L Street/Strip Dish Pistons (-8.6cc - -7.0cc)
$680-705 - Diamond LS1 6.0L Street/Strip Dish Pistons (-15.0cc - -13.7cc)
4.000" Bore, 3.622" Stroke, 6.098" Rod
4.000" Bore, 3.622" Stroke, 6.125" Rod
$705 - Diamond Resleeved LS1 Street/Strip Dish Pistons (-7.0cc)
4.100" Bore, 4.000" Stroke, 6.125" Rod
4.120" Bore, 4.000" Stroke, 6.125" Rod
$705 - Diamond LS2 6.0L Street/Strip Dish Pistons (-10.0cc)
$680-705 - Diamond LS3/L92 Street/Strip Dish Pistons (-25.6cc - -12.3cc)
$790 - Diamond LS7 7.0L Street/Strip Dish Pistons (-23.0cc)
$840 - Diamond LS1 5.7L Inboard Forging Race Dish Pistons (-28.0cc)
$840 - Diamond LS1 6.0L Inboard Forging Race Dish Pistons (-28.0cc)
$840 - Diamond Resleeved LS1 Inboard Forging Race Dish Pistons (-28.0cc)
$705 - Diamond LS1 5.7L/6.0L High Compression Dome Pistons (10.0cc)
$815 - Diamond LS1 5.7L/6.0L Nitrous Dome Pistons (10.0cc)
Piston Rings
$175 - Diamond Pro Select Plasma Moly Top Ring Set
$210 - Total Seal Steel Top Ring Set
Main & Rod Bearings
$130 - Clevite H-Series Main Bearings
$78 - Clevite H-Series Rod Bearings
Main Studs
$190 - ARP Main Studs
Balancing
$160 - Balance Rotating Assembly
]Hinson Motorsports, Inc
levi@hinsonmotorspots.com
205-267-6387 Shop
Your source for engine conversion packages and late model performance!
