February 28, 2021, 05:07:12 AM
Author Topic: WHICH WELDER TO BUY?  (Read 26422 times)
Re: WHICH WELDER TO BUY?
« Reply #90 on: November 02, 2017, 12:04:10 PM »
It has HF start, It seems like sometimes I have to almost touch the tungsten to get the arc started,  Im thinking I may not be cleaning my tungsten enough.  I do not have pulse unforunately but trying to learn the pedal
« Reply #91 on: November 02, 2017, 12:28:35 PM »
The AlphaTIG I use has HF start, but it does occasionally get fussy and I'll do a quick scratch to get it going.   Once I start welding a piece it generally works fine, it's just the very first start that can be inconsistent.
« Reply #92 on: November 02, 2017, 02:27:19 PM »
Im glad im not the only one, I wonder why that happens maybe the way things are grounded?  HF definitely takes a different path to ground than normal DC current
« Reply #93 on: November 02, 2017, 03:00:23 PM »
Yeah, I think HF spends more time in the "skin" layer, but it's been a while since I slept through EE 200 classes.
« Reply #94 on: November 03, 2017, 01:51:15 PM »
Lol something like that.  I work with RF welding machines at work.
« Reply #95 on: November 03, 2017, 07:23:21 PM »
The HF start function just serves to ionize the gas between the electrode and workpiece, creating a current path without touching the work.
« Reply #96 on: November 10, 2017, 05:05:59 AM »
Ive foind floorimg the pedal is much more effective, before I was rolling into it. If that makes sense
« Reply #97 on: November 10, 2017, 08:00:05 AM »
It does, as a higher voltage will jump a longer air gap.
So basically, you start with a burnout.  :D
« Reply #98 on: November 11, 2017, 12:52:15 PM »
I welded a bracket for the oil filter mount.
Had quite a bit of difficulty getting a good puddle established.
Every time I'd get the puddle to start to flow, I'd get a weird shower of sparks, and the puddle would get lots of porosity.
I kept going back to reflow it, and it would happen again.
First thought was this tube, which also carries the pedal mount, was chromemoly or something, but it's welded into the rest of the mild steel chassis.
Second idea was contamination on the ID of the tubing.
About the time I finally finished, with a not so pretty bead, it occurred to me that this was a short section of tube, sealed at both ends, and the problem may have been that the air inside the tube heated up and built up pressure, and whenever I'd get a puddle going the internal pressure would blow out through the puddle, both physically disturbing it and allowing oxidation to occur in the liquid steel.
It would blow out so bad I had to grind my tungsten several times to get rid of steel splatter on it.
Next time something like this happens, I'll drill a tiny vent hole somewhere in the section of tube to relieve any pressure buildup.
Any other ideas or suggestions are appreciated.
Hopefully my oil filter won't fall off in the middle of a race.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Reply #99 on: November 11, 2017, 12:59:43 PM »
Shit, it looks even worse in the pics than it did in person.  :barf:
« Reply #100 on: November 11, 2017, 06:24:32 PM »
Looks like a lot of heat in the tube.   How thick is each piece?    If one is much thicker, you want to concentrate the torch time on that piece.
It looks like a lot of heat and and some contamination to me, but I am very much not a pro.
« Reply #101 on: November 11, 2017, 08:17:10 PM »
Hell, I can't even call myself an amateur yet.  ::)
The plate is probably thicker than the tube wall, but the edge of the plate still wanted to melt more quickly, hence I had to concentrate heat on the tube.
Could oxygen blowing out from the inside of the tube cause that type of problem?  I'm sure it overpowered the Argon when it blew out.
I wish I'd thought to drill a vent hole before I finished.  As it was, each time it blew out, it got a little better, which is why I now think the inner pressure was being reduced.
« Reply #102 on: November 16, 2017, 10:16:00 AM »
Looks like lots of contamination, what size nozzle and gas flow are you running?  A vent hole would definitely help too.  Did you wipe everything with acetone before welding too?  What amps are you running, it really looks like there was some undercutting.  Do you have time to grind it off and try again with a hole?
« Reply #103 on: November 16, 2017, 03:40:11 PM »
Thanks for the input.
The nozzle is whatever was in my WP-26 torch.  Gas flow was set at around 10 CFH I think.
I thought about cutting it off and redoing it, but this is hidden by the aluminum firewall.
I hit it pretty hard a bunch of times with a hammer, it sounded solid and showed no signs of flex or cracking.
I think it'll hold the oil filter mount just fine.
« Reply #104 on: December 02, 2017, 10:12:01 PM »
Heres my first tube project, modified steering link for the fb
