I am beginning to step into the LS world and need some advise.
I understand the 411 PCM was used in 2001-2002 F bodies after the 4896 in 99-2000 models.
I have read that you can inerchange them both without any issues in 99-02 F Body harnesses. Can someone confirm that?
What are the main differences between both? Is it faster processors or additional programming features? If I can choose right now, is tere an advantage from one over the other?
The 0411 PCM is a bit more expensive. There should be a reason for that, I guess.
Thanks for your opinions.
