August 21, 2019, 06:06:12 AM
Author Topic: My 4.3 vortec 84 FB  (Read 48958 times)
Offline matt
Re: my 84 FB
« Reply #30 on: December 02, 2010, 07:48:35 PM »
How are you planning to mount your 3 link?  I'm curious about the body mount side since you said you want to do an offset non interior mounted setup.
I ran mine centered and through the floor.  It was a pretty simple install and fits under the storage bins.
81 S LS1/T56
Ford 8"
Panhard bar & 3 link
FC front subframe
TII brakes
Offline rk970
Re: my 84 FB
« Reply #31 on: December 03, 2010, 12:24:00 AM »
I am going to the pull-a-part with a battery powered sawzal and cutting out the rear tunnel under the bins of a wrecked FB.  I will cut the top off and the right side of mine, and, well do a little plastic surgery.  I can weld sheet metal pretty darn well... So basically I am making the tunnel taller and wider to the right.. (I only have to make wider to the right by about 1.5")
It will be a little while before I tear into the rear end...I have to finish my fuel rails, Run 3/8" hard line from the fuel pump (that still has to mounted yet), pull the tank and weld in a sump to it,  put the motor back in, wire up the EFI, mount the FPR plumb it, mount the MSD/Coil, figure out throttle cable, speedo cable, mount the radiator, clean up the wiring under the dash... on an so on.,..
I have a white dry erase board in the garage, I listed everything that needs to be done front to back. As I finish a task I mark it off..  Rear end is toward the back..
Are you using a panhard bar or the stock whatts link???  with your three link??
Offline matt
Re: my 84 FB
« Reply #32 on: December 03, 2010, 10:20:21 AM »
I see.  The factory tunnel seems like the only hurdle to keeping the bar outside of the body and asymmetric.  The widened tunnel would be interesting to see when you finish it.
I've got a panhard bar with the 3 link.
81 S LS1/T56
Ford 8"
FC front subframe
TII brakes
Offline rk970
Re: my 84 FB
« Reply #33 on: December 30, 2010, 03:37:08 AM »
Well I was slowed down by the holidays,  but I did manage to get out in the garage and sneak in some work..
Like Fuel rails
I even found a few hours to assemble my MSII EFI..
I have to make the stands to attach the fuel rails to the intake manifold.  Also  plumb the front of the rails to each other under the plenum  with -6 aluminum hard line..
Sorry but I did not get any pics of making the fuel rails,  It was cave man done like in a drill press with a dial indicator attached with various clamps..  17/32 and a 13/32 bits a counter sink and lots of polishing by hand of the injector pockets in the rails..
rk
« Last Edit: October 03, 2013, 01:29:44 PM by rk970 »
Offline aleXander
  • "George fucking Bush"
Re: my 84 FB
« Reply #34 on: January 01, 2011, 02:13:24 PM »
Nice intake setup!
V8Mongrel
  • Guest
Re: my 84 FB
« Reply #35 on: January 04, 2011, 10:18:52 AM »
Any details you can five on the MSII would be great.
Offline rk970
Re: my 84 FB
« Reply #36 on: January 04, 2011, 11:49:19 PM »
five ????  what would you like to know?
Ohh give...
MS v3.0 board, MSII processor.   MSExtra code V2.1.0.  Mods on the board to run a GM 7pin HEI module and the GM idle stepper motor..
I also will be using the relay board http://www.megamanual.com/v22manual/mwire.htm#rb    The idle relay is going to be used to power a hiamp relay for my e-fan (it can be set to come on at any temp I want in the code)
I also have one of these .
http://www.14point7.com/NAW_OEM.php    (I do not think he has any left the page was in my book marks)
My father worked for the department of defense for 38 years in research and development of electronic warfare,  I learned how to solder a few things ..  ;)
« Last Edit: January 05, 2011, 12:51:57 AM by rk970 »
Offline rk970
Re: my 84 FB
« Reply #37 on: January 26, 2011, 01:37:23 AM »
Worked out some details of the intake fuel rail mounting..
Getting the dimensions for the spacers
Cross over pipe, had to clear the thermostat housing
Cross over pipe, cleaned up, trimmed the mounting  bars and radius the ends
Mount cleaned up,
Shot of the rear, I put nipple in the 1/2" spacer for the FPR and the MAP sensor..
You can also see in this shot the 3/8" NPT holes in the #6 runner and into the plenum..    I was thinking of using the center one for PCV and the one the runner for vacuum brake booster..  opinions welcomed if there is a better way..
Another shot of the cross over pipe
RK
« Last Edit: October 03, 2013, 01:47:32 PM by rk970 »
Offline rk970
Re: my 84 FB
« Reply #38 on: March 31, 2011, 05:45:29 PM »
Getting ready to put it in..
Close up of the clutch fork.
Clutch slave (CNC from speedway motors) finish the mounts and cleaned up.
I decided to paint the engine block semi-gloss black.  The chevy orange was just imo "gay"  the final paint on the car will be black.
Cross member bolted in
Pulled out the fuel, return and vent lines since I will be running new -6 hard line
I can't remember were I got the starter, but is is a mini, permanent magnet, planetary gear reduction with a stock type mount..
-6 hard line for the PCV,  -6 90* fitting for the brake booster, billet dizzy and oil pressure sender.
The plan is to get it in, wired, plumed, drive line done and get it started.. Then it is all being pulled out. The shell will be placed on a 1x1 frame with 10" castors and the body/paint mayhem will begin.
rk
« Last Edit: October 03, 2013, 01:55:11 PM by rk970 »
Offline rk970
Re: my 84 FB
« Reply #39 on: March 31, 2011, 07:06:07 PM »
Its in took 30min..
Yes it is a shifter out of an S10 ,, it will be cleaned up a "bit"
« Last Edit: October 03, 2013, 02:02:26 PM by rk970 »
Offline N2v8fcs
Re: my 84 FB
« Reply #40 on: April 02, 2011, 08:32:09 PM »
nice work I love your attention to detail.
:drive:
Offline theantirotor
Re: my 84 FB
« Reply #41 on: April 02, 2011, 10:00:13 PM »
this is a cool build!  somehow i had never noticed it before!
:bacon:
Offline rk970
Re: my 84 FB
« Reply #42 on: April 05, 2011, 01:33:24 AM »
I got my upper plenum on.. here are a few detailed shots.
If I have some time tomorrow I am going to bleed the clutch and try to figure out how to post a video of the throw out arm.. (super geekish I know)
RK
« Last Edit: October 03, 2013, 02:07:10 PM by rk970 »
Offline rk970
Re: my 84 FB
« Reply #43 on: April 16, 2011, 03:20:37 AM »
At it again, running -6 hard line.
Both feed and return are -6 (3/8") steel hard line
Aeroquip FC332 push-loc hose
Feed and return mounted on fire wall (bottom of brake booster is on upper right)
Again feed and return, regulator and vacuum line to brake booster (oil pressure sender also in pic)
In the above pics, Bosch 0580254910  195L/Hr at 3.0bar (130 @ 5bar). Fram G3727 Fuel filter, very common on 90's+ Gm autos, Earls 991955 16x1.5mm (saginaw fitting) to an -6 for the G3727 filter, Russell 640913 12mm to an-6 banjo fitting for fuel pump, Various -6 / -8 fittings, 1/2" annealed pipe that will be brazed into the top plate on the tank for the suction line, 3/8" line for return into tank, stock fuel pump mount (it will be modified to mount the hi pressure pump)
-8 push loc hose,  -6 push lock hose (GoodYear insta grip)
Pic of the clutch pedal and master under the dash/pedal cluster
« Last Edit: October 03, 2013, 02:14:42 PM by rk970 »
Offline dream36realms
Re: my 84 FB
« Reply #44 on: April 16, 2011, 07:44:47 AM »
nice work. thanks for the updateon the fuel lines. I havent got to that point yet but will be needing to do the same so I may copy your idea a bit.
日までに仕事および夜までに虐殺。
を下って、人類と
