No, not that EcoBoost. This one:
I
think it's going to work, so I'm going to start a thread.
I want a quick, reasonably efficient, stick, 4 door, fun daily driver. Back in 2015 I put a 302 in an M3 and I've been rocking that for the past 6 years. It's close to what I want, but it's stinky (no cats), hot (no AC), gets 15mpg at best, and the chassis is showing its age. It's an awesome racecar, but not the best daily. Enter the RX-8.
It's nice, but it's not that quick and basically the same gas mileage as the M3 for half the power. But at least the AC works.
My first idea was a Mustang V6 - 300hp, lightweight, cheap. Should be a win, right? Nope! The upper intake is an absolute killer.
No way that's fitting under the hood. Okay, what can I get with a slimmer intake manifold? The GM V6 is fine, but it's been done before. Well, the EcoBoosts have a shorter manifold that sits down in the valley...
I had planned to turbo the 3.7 eventually so this just accelerates my plans.
The 2.7 is nice because:
- Dual injection means I can ignore the direct injectors and run E85 via the port injectors without issue
- Little baby turbos for instant spool
- CGI block is sweet and built for boost
- Lots of instrumentation for data collection
But will it fit? Almost!
Stripped off the turbos, the EGR system, and weighed it. Came in at 366lbs, same as the 3.7. Not bad for having a CGI main structure for a bazillion times more strength.
Went ahead and notched the subframe a bit to give me a little more wiggle room.
Snugged it up against the firewall
The hood almost closes. Without the insulation it'd probably latch. I may have to get the tiniest bit fancy to get some extra clearance.
Started working on engine mounts:
As for the rest of the drivetrain, a few serendipitous things came to light.
The Coyote flywheel bolts straight up:
With the addition of a 3.7 V6 manual block plate and by moving one dowel pin, the V6 Mustang MT-82 bolts right up:
The crank is already drilled for a Mustang pilot bearing. And by using a 3.5/3.7 starter, the flywheel engages and the engine turns over.
ECU will be a Megasquirt. Might work, might not. Initial tests are promising.
Rear end will be Explorer 8.8. I already have one, plus the Ronin axles, I'll adapt it to the subframe myself.
Turbos will have to be rotated down a bit to clear the frame horns and fit in the engine bay. That means I need to source adapters to change the stock turbo o-ring fittings to -AN lines. I also might have to do a scavenge pump because the oil drainback holes are so high in the block.
That's basically where I'm at. I need to get the engine mounts made so I can get that and the transmission into place and move on with the hundred other impossible things to figure out.
