January 22, 2021, 10:37:40 PM
Author Topic: 044 pump surge tank mount  (Read 2580 times)
« on: October 12, 2019, 10:39:12 PM »
I'm going to make a surge tank that fits between the subframe and tank. I want the pump to be mostly submerged but cannot seem to find a seal.
Anyone have ideas?
Worst case I but some cheap crap tank off eBay and make it my own.
Offline shainiac
Re: 044 pump surge tank mount
« Reply #1 on: October 12, 2019, 11:48:56 PM »
I'm using an Integrated Engineering (IE) surge tank which looks to be what a lot of the eBay sellers have knocked off. It has a beefy 1/2" bulkhead and submerges and seals a single or double 044 pump with an oring. I have mine mounted on it's side and still works well. It also uses ORB fittings so no wories about getting thread tape inside the tank. I believe someone did a write up on rx7club installing an IE surge where you're suggesting.
716whp/662wtq @1.3bar
« Reply #2 on: January 13, 2020, 12:46:28 PM »
You could always sump your gas tank and mount a external 044 in the same space your talking.  One less pump, I have run mine down to 1/8 and corners hard with no loss in FP.
