June 18, 2019, 04:39:46 PM
Author Topic: Clutch not fully disengaging? Bigger master cylinder?  (Read 177 times)
Offline AZieger
« on: June 03, 2019, 03:12:03 PM »
During my LS3 swap I replaced the clutch with a new LUK aftermarket OE replacement unit and an Exedy chromoly flywheel.  Also a new LUK slave cylinder, pilot bearing and throwout bearing.  Using a new Wilwood 7/8" MC and a braided stainless line.  Also using a TICK remote speed bleeder.
Clutch engagement point feels pretty good, maybe 1-1/2" from the floor.  "Normal" I would say.  Adequate free play at the top - about 1/8".  Starts to build resistance early in the travel - maybe about 1/2" past the freeplay.  So far I have about 300 miles on the setup altogether.
But ever since day one, the 1st to 2nd shift has been harsh (TR6060).  Other gear changes can be harsh as well, but 1-2 is the worst.  Even when shifting slowly, there is a prominent "thunk" sound and it can be felt through the chassis.  Also when putting the car into 1st sitting still with the clutch pedal fully depressed, I can feel the car move slightly and feel a little "thunk".  So obviously the input shaft is still spinning for some reason.
I have bled and re-bled the system three times.  I used pressure, vacuum, and both.  Standard and reverse bleed.  Bench bled the MC too.  I am 99.5% sure there is no air in the system.
In an attempt to solve the issue, I have unscrewed the clutch switch nearly all of the way, and also have the master cylinder clevis sitting near the end of its adjustment range.  As a result, the clutch pedal has a lot of travel compared to other cars that I have owned - it sits about 1/2" higher than the gas and brake.  It is also one of the lightest pedals of any car I have had.  And it still drags.  This leads me to wonder: What about a larger bore master cylinder?  Maybe 15/16"?  I wouldn't mind a heavier pedal with reduced travel.
A quick search of the subject suggests that 7/8" is plenty, and that a larger bore could actually over-stroke the slave if one is not careful.  Is this true?  Should I be looking for other solutions?  It is possible that my pilot bearing is bad somehow and causing the input shaft to never stop turning?
Offline AZieger
Re: Clutch not fully disengaging? Bigger master cylinder?
« Reply #1 on: June 03, 2019, 03:15:10 PM »
Also FWIW, I did not shim the slave cylinder as I was not aware that this might be necessary.  Although given the fact that the pedal builds pressure so early in it's travel I feel like this is not likely to be the issue.  When the engine is off I can hear a faint "creaking" sound of the clutch diaphragm spring moving throughout most of the pedal stroke, starting near the top when the pressure builds so I don't feel like much of the movement is being wasted to clearances.
« Reply #2 on: June 03, 2019, 04:48:42 PM »
FC or FD?
With an FD I moved to a 3/4" master as the engagement was actually much too fast with a 7/8" and my twin disk clutch.  It bit very aggressively and was difficult to drive smoothly.
Was your pushrod modified to be longer?  Hinson did this with the old 7/8" wilwood kits.
Offline tai-lun
« Reply #3 on: June 04, 2019, 05:20:46 AM »
I'm having the same issue with my Hinson modified 7/8", I'll be trying the clutch pedal adjustment you did when my car is back from the bodyshop to see if there is improvement but I'm a bit stuck in the same boat. Hopefully some solution can be found for this clutch issue soon..
Tai - 93 LS2 Ronin Widebody FD - rebuild time with ITB's soon... :banghead:
Build Thread: http://www.norotors.com/index.php?topic=9172.0
  • I steer with the gas pedal.
« Reply #4 on: June 04, 2019, 10:23:16 AM »
You guys may need to measure and shim the slave.
That said, have you ran a T56 or TR6060 before? Was yours used? Generally if the clutch is dragging, you won’t be able to shift with these transmissions.
If you double clutch does the thunk go away? It can be normal to get a mild clunk going into gear with these transmissions. The input shaft is not going to stop spinning the moment you depress the clutch.
If you have the clutch set to disengage too high in the travel, sure, it is possible to over stroke the clutch that depends on your clutch and shim setup. If your clutch is indeed dragging you are not over extending it obviously.
« Last Edit: June 04, 2019, 10:35:18 AM by largeorangefont »
Offline tai-lun
« Reply #5 on: June 05, 2019, 02:49:59 AM »
My T56 was brand new upon install, F-body with a scarab clutch at the time. It now has a Z06 LS7 clutch and RAM flywheel but only recently has the foot to the floor pedal so the car moves on startup if you have it in gear and clutch pedal to the floor.
Clunk with double clutch but not all the time, I think I've got the mild clunk typical with T56's though. I'll hopefully be looking at it before weeks end but my car is still at the bodyshop where they are not so stoked on now having to push it everwhere.
