October 19, 2019, 01:31:59 PM
Author Topic: Widebody Rivet question  (Read 2468 times)
    • Venom Speed Shop
Re: Widebody Rivet question
« Reply #15 on: March 18, 2019, 07:37:26 AM »
I’m late to the party but if your using the feed rear over quarters, there is no need to cut anything!  Just need a very aggressive roll, which gets the metal fender to meet the Fibreglass over fender.  Much better imo, cutting and welding usually just creates a rust spot.  Not to say it can’t be done right but in this Situation I don’t see the need. I’m currently running 295’s in the rear but I could easily fit 315’s with the right offset wheel.
definitely not too late to the party.  Thanks for the advice.  I have access to a fender roller.  My wheels are 18x10.5 +22 in the rear with a 295 wide tire.  I am on K-sport coilovers also.  Do you have any pictures of the "Aggressive roll" you did so I can have an idea of how far to go?
1995 RX-7 - LS1, T56: LS6 Intake, Feed wide body, Feed CF Side skirts, Ray's Gram Lights, K-Sport coilovers, 99 spec\ tails and spoiler, SpeedHut Gauges, Aeromotive fuel pump, TwinZ Rear Diffuser
2000 Ford Excursion - V10 Tow monster
« Reply #16 on: March 18, 2019, 05:57:59 PM »
I checked and I donít have pics of the roll.  I have lots of other pics but not a good pic of the actual roll.  My wheels are 18x10 +22 offset with a 12mm spacer so offset is really +10.  Just to give you an idea of how much space there really is.  Remember you can fit an 18x10 +50 offset on the stock body.  So, quick calculations tell me I can fit an 18x11 easily.
    • Venom Speed Shop
« Reply #17 on: March 19, 2019, 06:57:04 AM »
right on.  did you flare the body a bit or just really flatten the lip?  I am assuming you flared it out a bit.   I have an 18x10.5 +22 with no spacer but on K sports.  I have it a bit too low right now.  I will play with the ride height when I get around to it.
    • Venom Speed Shop
« Reply #18 on: April 25, 2019, 08:19:41 AM »
Aggressively rolled my fenders last night.
« Reply #19 on: April 25, 2019, 09:22:30 PM »
  yes!  Thatís exactly what I was talking about.  You might need a little more.
    • Venom Speed Shop
« Reply #20 on: April 26, 2019, 07:40:46 AM »
  yes!  That’s exactly what I was talking about.  You might need a little more.
I'm going to take it out this weekend and see if it rubs or not.  I may raise the suspension a little if necessary.
    • Venom Speed Shop
« Reply #21 on: July 18, 2019, 01:35:38 PM »
Just to dig this back up.  I ran the dragon last weekend and didn't have any rubbing issues.
The only issue I had was when I did a huge dump into 2nd gear and hooked up my car squatted and I rubbed a little on the passenger side.  The drivers side is stretched a little better than the pass.
