April 26, 2019, 02:01:00 AM
Author Topic: 1994 Mazda rx7 with t56 and ls1  (Read 1394 times)
Offline Mrtorgue
« on: January 21, 2019, 10:00:20 AM »
PRICE $30,000.... After i bought this from the previous owner life hit me in some unexpected ways, home problems and health problems are forcing me to do this. So basically i got the car drove it home from Utah and parked it. Drove maybe 100 miles since then. I canít seem to load pictures so for pictures please text me at 2537536229
1993 RX7 Black Touring Model (Originally an Auto)
HISTORY:
Originally a Hawaii car nearly its whole life. Bought the car back in 2014 previously swapped with a grannies kit. Not sure when the swap was performed exactly. The engine did come out of a 2002 Camaro along with the T56. I brought it out to Utah when I moved back in 2016. No rust from what I have seen. I have been improving on the car the day I bought it. Below are the mods/improvements I have performed. All of the front and dash wiring has been gone through. Anything not needed was de-pined and removed and re loomed. no half ass wiring splices and cuts. Everything is plug and play including chassis to engine wiring. I have kept all receipts for my purchases. Clean and clear title. Please, serious buyers only. Asking $31K.
Drivetrain
- LS1/T56 from 2002 camaro
- Hinson subframe/trans mount/driveshaft
- Samberg diff brace
- Improved Oil cooler thermostat/custom 10AN lines routed to OEM cooler
- Turn One PS pump/custom 8AN line routed to OEM trans cooler
- Samberg Radiator with shrouds sprayed black
- A/C!! blows cold and uses halfspecs PCM cooling fan and a/c controller
- LS6 PCV mod
- Accessory Brackets powder coated
- Willwood Clutch Master
- LS7 Clutch
- Tri-Ax Shifter
Suspension/Brakes
- Rebuilt OEM calipers powder coated gold
- Hawk Pads
- Brembo slotted/drilled rotors
- Supernow Aluminum Brake cap
- Alex Rodriguez ABS delete with willwood prop valve
- Sakebomb Garage Stainless braided lines front/rear
- Tokiko Illumina shocks with new OEM bushings
- Tein H-Tech springs
- Swaybars powdered red
- Supernow Front Swaybar mounts
- Improved Racing Strut Bar with Master Cylindar Brace
- 3in exhaust off the headers (no cats!!)
- Racing Beat Cat Back dual tip
- Corvette Fuel filter located in rear and pressure gauge off the rail
Exterior
- 99 Spec bumper with 99 Rebar (Note: All 99 parts are OEM)
- 99 Lip
- 99 Brake ducts
- 99 Spoiler
- BBS RGR's (essentially 99 spec rims but an inch wider in the rear)
- Shine Auto carbon rocker panels
- Halfspec S2000 antenna mod
- New OEM Door Handles
- Sakebomb Garage Premier Headlights
Interior:
- All black Interior with every panel updated to the 94-95 textured verson
- Original working passanger door handle
- Bubble Tech map lid
- Alpine stereo with front/rear speakers
- Angry Panda Spirit R Recaros
- Sakebomb Garage passanger footrest (powdered black)
- New OEM trans tunnel cover
- Efini Steering Wheel
- Cobra Shift Knob
- Dual dash gauge pod w/ Greddy Oil pressure and PLX OBDII gauge
I know im missing things. Ill add them as they come to mind or i see them.
« Last Edit: January 21, 2019, 10:07:44 AM by Mrtorgue »
Offline Mrtorgue
Re: 1994 Mazda rx7 with t56 and ls1
« Reply #1 on: January 21, 2019, 10:01:40 AM »
Hereís a picture.
Offline Mrtorgue
« Reply #2 on: January 21, 2019, 10:03:48 AM »
Hereís a few more.
Offline Mrtorgue
« Reply #3 on: February 11, 2019, 11:42:38 PM »
Sold!
« Reply #4 on: February 12, 2019, 02:12:09 PM »
Is Ramone's car becoming the town bicycle?
