July 19, 2019, 04:40:25 AM
Author Topic: "Doda" '93 FD NASA TT Build  (Read 2770 times)
Re: "Doda" '93 FD NASA TT Build
« Reply #15 on: February 03, 2019, 10:32:23 PM »
I like the overheating gauge.
Offline PeakAlpha
« Reply #16 on: February 09, 2019, 11:05:36 PM »
All the girlies do.
Offline PeakAlpha
« Reply #17 on: March 02, 2019, 11:16:04 PM »
HOKAY, so. Now that the car was actually started, I decided to put a fuse box in and start cleaning up the ol’ rat’s nest that is the inevitable result of any project car on this level. So I went and bought a dick-ton of loom, and started wrapping wires. This is the nicely loomed wire and my junkyard Blazer fuse box. I also put my hand in there for the arousal factor.
I was surfing around on this one site called NoRotors, and found an oil cooler that somebody was selling and decided to buy it. Because why not? If I recall, it is a stock FD RX7 oil cooler (someone else can probably confirm by looking at it), and the dude had tacked some mounts on it that still work. Not super sexy, but it works fine and I have had no problems with it so far.
Next I decided to mount my battery. I chose to put it behind the passenger seat. One could argue that shifting more mass to the rear would be more desirable, but this will put it closer to the center of rotation of the car and it just fits nicely right in there so I went with it. It is shown in a crappy Marine battery box that I got from Poop’s Hardware or something, but I eventually got a nice Moroso box with a tube to vent the fumes to underneath the car. I guess batteries tend to off-gas, so there is a stipulation in the NASA rules about venting it. ANYWAYS here is the battery. Sorry for the grainy bullshit
Now I was starting to work towards getting this stupid thing drive-able. I decided to mount up my gauges using some steel plate. I have two big problems as a fabricator. #1, I have little to no skills when it comes to fabricating, and #2 I am aesthetically retarded. So this is what my first cut at it came out like. I actually screwed up and cut only 5 holes  for 6 gauges, and then tried to fix it, so that is why the three gauges are clustered so closely together on the right side. On a side note, do NOT purchase hole saws from China. I got through like two holes and the blade was already junk. I think they must make their steel from a Gorilla’s dick cheese or some shit. The little piece of plate on top of the steering column mount is for the tachometer. I used the cross-brace that was originally designed to mount the dash, but obviously without the dash
Next step was to get the driver seat mocked up so that I could figure out where I needed to mount it so that I was comfortable in there. I ended up with a Kirkey aluminum seat with side-bolsters for my helmet. It works pretty good. I am 6’2”, so this damn coffin is not exactly the most comfortable fit for me. I ended up mounting the seat pretty darn far back. About as far back as it could physically get with the roll cage in there. Even with that, I still can easily manipulate the pedals, and my knee just misses the bottom of the steering wheel on my heel-toe motion. The only thing that kind of sucks is that roll bar padding on the side of the halo tube interferes with my helmet when I am sitting in there, so it pushes my head to the right a little bit. I took that piece of padding off for now and it barely leaves enough room for my head to be straight while I am sitting in there. Turns out being tall blows Donkeys for racecars. Anyways, here is a picture of me trying out the fitment on the harness. Deeeeelishuss.
Aaaaaaand here is some dickweed in his unfinished racecar. Some day I will be able to exceed the speed limit in this thing.
But for now I was just pretty damn happy to be making progress. A lot goes into building any car, as most of you well know. And keep in mind that I am doing just the barest, most simplified version of this whole thing. No interior, no AC, no heat, none of that garbage. Just a boy and his dream of pissing off the neighbors with his open-header V8.
« Reply #18 on: March 04, 2019, 01:12:22 PM »
I feel like your current windshield will make it hard to see the apexes well.
Offline PeakAlpha
« Reply #19 on: March 09, 2019, 07:39:53 PM »
I dunno man, that sh*t is KUSTUMMM!!!!!
But yeah I taped trash bags on there to paint the interior. It's pretty high-end  :barf:
Offline PeakAlpha
« Reply #20 on: March 11, 2019, 10:53:50 PM »
I started putting some finishing touches on the car at this point. I painted the brake calipers red with some VHT paint from the parts store.
In hindsight, I would not do this again. Brake fluid ends up making the paint run and it just doesn’t matter at all for a race car. Just a pain in the ass for really no benefit. They will shortly end up being covered in brake dust anyhow. I eventually ended up swapping one of my front calipers out because I had a spare and a bleed nipple snapped off in the caliper and would NOT come the Hell out. Then I had the FR caliper painted, and the FL caliper bare aluminum. So I took some brake cleaner to the FR one and tried to get most of the stupid sticky BS paint off of there. Long story short, I now have one pink and one bare metal caliper, so whoopee for me!!! I’m a total tool!!!
Got the fluid reservoirs mounted in the engine bay.
This works fine, although they are BARELY higher that the master cylinders in the cabin, with a big loop in the line which makes getting air bubbles out of that short run of tube kind of a beeotch. Luckily I can just run a short-ish length of tube from the MC outlet back into the reservoir without removing anything, making it super convenient to bench-bleed everything in the car. All-in-all not a bad deal at all.
One weekend I decided to throw the body on the front and see how it looked.
And then got the wheels back on there for the Helluvit and rolled it out into the driveway to see what it would look like
Kind of looks like an off-road vehicle with the stock springs in there. I haven’t weighed the damn thing but I know I have taken a significant amount of weight out of this thing, so perhaps it’s not surprising that it rides so high. JEEEEEEP BRAAAHHH!!!!
She looks pretty good from the right angle however…
Next up was to figure out my throttle cable. I still had the stock FD throttle cable, and I am cheap/too lazy to figure out what I needed to do to get a new throttle cable that would fit the LS1 bracket and the FD throttle pedal. So I said EFF it and made my own bracket with science.
Once I had all of this stuff together, the car was finally drive-able… Well, sort of. The un-tuned car was not really drive-able as the engine would die once any load was put on it. Not being a tuning guru, I decided to make a Dyno appointment. So I found some guy who was willing to do it and got it all scheduled. On the big day, I threw the car on the ol’ trailer and pulled it the 20 minutes down the road to the dyno shop and unloaded the car. Here she is sitting out front in all her glory.
Seeing as how the tune was all sorts of catty-whompus, the tuner dude had trouble getting it up (ha!) on the dyno, but eventually we prevailed and got Doda all strapped in. The guy spent the first part of the session obviously getting the thing drivable. Then he proceeded to some light throttle pulls and then partial throttle pulls. I didn’t get a great video of any WOT pulls because the rear tires were slipping on the dyno drums and he had me and my buddy hop in the trunk to improve the traction. Safety first I guess..? As I get older this is one of those face-palm moments that I always think back on and cringe. So that was sketchy, but here is a decent part-throttle vid.
https://www.youtube.com/watch?v=4H54F2W4edQ&feature=youtu.be
On several of the WOT pulls, tuner bro kept asking me about the rev limiter and what I had set it at, and saying that it was too low and whatnot. I had no idea wtf he was talking about at the time, but the reason for his inquisition would become painfully obvious to me later. More on that in a future post. Overall things went really well. I had a bit of oil pooping down the back side of the engine at some point, but it turned out to just be a loose oil pressure sensor so that was super easy to fix. All-in-all it was a success, and I had just a few things to do before I would brave an event. But for now, I was pretty stoked with the result. Car made 343 HP to the rear wheels. The bumpy bullshit at the beginning was when the wheels were slipping on the drum. Not bad for a mostly stock LS1 with straight-through exhaust and a tune.
And that’s it for now Pistards. Gotta wait to see how she did at her first Auto-X. Hope y’all are enjoying this. Thanks to everybody who contributes to this forum for all the information over the years. It has really helped me and countless others I am sure!
Offline PeakAlpha
« Reply #21 on: April 29, 2019, 11:09:33 PM »
Hello again Pistards! Finally figured out how to edit a simple video so I threw one together highlighting a couple of auto-x's that I did at the end of my stint in Blowhio. Allah willing I will be getting better at this whole “making videos” thing, so please forgive me. Hope you guys enjoy seeing the car finally doing what it's supposed to!
https://www.youtube.com/watch?v=a-WNbWKtHz4&feature=youtu.be
Alright, I friggen give up. I can't figure out how to embed a video on here. I am just an internet simpleton. Sorry guys.
Anyways, as you can see I had a bunch of issues with the ECU/CPS. I did a couple of runs and logged the data from the ECU, and basically it was pissed off because it was not getting a clean signal from the crank sensor. I tried some things with shielding the signal wire, and even threw a new CPS in there but still had the same issue. Eventually I re-flashed the ECU to see if that would help, but it just ended up screwing EVERYTHING up and the car ran like a pile of horse piss. Not sure what the deal was with it. I was using a MicroSquirt and running batch fuel/spark. I tried getting help from their support forums (which was the impetus behind re-flashing the stupid thing) but it kinda pushed me in the wrong direction.
After the last Auto-x on the video it was winter time (because the Mid-West is bullf**k) so I had to park it for the season anyways. And then the following year I separated from the ol’ military and moved across the country so I REALLY got nothing done on the car for pretty much all of 2017. Anyhow, we will pick back up in early 2018. Stay tuned for more adventures of a pathetic turtle rapist trying to do car sports.
« Reply #22 on: May 01, 2019, 01:37:23 PM »
Looks like a lot of fun at the AutoX.
Offline PeakAlpha
« Reply #23 on: May 01, 2019, 11:19:54 PM »
Haha, yeah man it is frustrating at times but fun. At least as much fun as standing in a parking lot for six hours in exchange for six total minutes of "track" time can be lol. But it could be a helluva lot worse, that's for damn sure.
« Reply #24 on: May 03, 2019, 06:09:11 PM »
Digging the build.  Sarcasm and racecars will get you far around here.   :bacon:
  • I steer with the gas pedal.
« Reply #25 on: May 05, 2019, 06:31:30 PM »
That’s why I don’t AutoX lol.
Offline PeakAlpha
« Reply #26 on: May 06, 2019, 10:44:00 PM »
Glad you are enjoying it man!!! (non-sarcastically of course)   :yay:  :punch:  :drive:
Offline PeakAlpha
« Reply #27 on: May 06, 2019, 10:46:32 PM »
Quote
Ha! Yeah I don't blame ya. There is a reason I am not doing an Auto-x build. But it is a good way to get the thing shaken down before I show up to a track day with a leaky mis-firing piece of crap! Best to get those issues sorted at 35 mph than have something go wrong at 135 mph (I assume).
« Reply #28 on: May 07, 2019, 11:41:09 PM »
Quote
I use the streets for that.. yo.  :yay:
No I agree with you.
Offline PeakAlpha
« Reply #29 on: May 08, 2019, 11:10:07 PM »
So, Summer 2017 I moved away from the MidWest and ALL the way down to the foreign land of Arizona. Once I got settled into my new life a little bit, it was time to sit down and figure out how to get my pile o’ piss to run well again. At some point I decided to ditch the Microsquirt. It was just too much of a project. If it had been working the way it should it would have been one thing, but it didn’t seem to be properly operating, so rather than spending a bunch of time and money with another one I just said eff it and decided to buy a Holley system. So, I set to work re-wiring the car to accept the new Holley. I just needed to make a few small changes here and there, and fix some of the crappy things that I had done earlier in the build process.
One thing that I changed was that I got rid of my POS Blazer fuse box, and replaced it with a nice Leash electronics unit. Not an enormous change, but it sure cleaned up the wiring and fits nice on my transgender tunnel.
As you can see, I mounted the ECU on the ol’ firewall there. It works. I have got to get some AL panel to cover it up at some point though. It’s too easy for stupid passengers to kick the damn thing currently. Also, the fuse box is SO FULL OF SPAGHETTI!!!!!! So I cleaned it all up and made it look SECKSAY!!!! Or… Well, at least as sexy as an impatient engineer can make it look (hey, stop laughing you bitches!).
Once I got the thing running again, I had a buddy help me set it up so that it would run good on my first tune, and so that the self-learning mode was enabled. That feature of the Holley is super badass. I live in a small redneck town, so access to tuners is hard to come by. But there are benefits to living in the middle of nowhere, mainly that nobody gives a flying f**k what you do. So that’s why I swung down to the local DMV to get a license plate for my bare-bones totally stripped down racecar with a roll cage in it, no headlights, no turn signals, no airbags, etc… And nobody cares.
 I needed a way to test my stupid racecar out without having to do ALL of my testing at the autocross or the track or whatever. That just gives you such limited test time. I try not to do anything too retarded on the street with my car. I have driven (respectfully) past multiple cops and none of them have looked twice because I don’t drive like too much of an A-hole. So anyhow, I put some miles on the car, and started to work out some problems that I found. The first biggie was a FREAKING OIL LEAK (I know you guys are probably fucking SHOCKED).
I ultimately tracked it down to the front main seal. So I decided to replace the damn thing. I went on the interwebs and found a nice little tool to help me out that is designed to locate the timing chain cover with respect to the crankshaft to ensure that the seal is centered on the crank pulley. Once I got all my parts together, I set to work replacing the seal. Turns out the crank bolt was FINGER TIGHT!!! I put a socket on there and it just started turning with the weight of the ratchet. So, the dicktards who own the “performance shop” that built my engine decided to just not worry about tightening it. At this point, I could go on a rant about shops and how much I hate them and how much they try to rape everyone and whatever, but I will keep the bitching and moaning to a minimum. I realize that somewhere there is a decent shop. I just have not ever personally seen one. They all piss me off. Anyways, I got the stupid crank pulley off lickety-TITS due to the loose crank bolt, and replaced the seal even though it may have still been good. Who the eff knows whether “Shitty’s Speed Shop” used a new crank seal when they were sucking at their jobs.
Anyhow, I got a new front seal in there and took her for another couple of test drives. And guess what? OIL LEAK!! PIIIIIIIISSS!!!! The good news is that now it was coming from the rear main seal.
I am guessing that all of this was happening because the damn car had been sitting for so long during the move and whatnot. At this point, I was DAMN determined to get this thing together and reasonably not shitty because it was now early Summer 2018, and I was bound and determined to get on track for the 2018/19 track day season. So I put her up on jack-stands and pulled the stupid transmission out. Bought another tool to center the rear cover much like the one for the front cover from above. Got the clutch off and got the new rear seal in there.
While the transmission was out, I decided to take it to a local guy who rebuilds T56’s to refresh the synchro’s etc… in the transmission. The dude got it pulled apart and ordered the necessary parts, including a Viper 2nd gear and new synchro’s. As it turns out, rebuilding the transmission at that time turned out to be sort of a mistake. But I will get into that later.
In the meantime, it was starting to look like I was ACTUALLY going to get this stupid thing together by the end of August and make the first NASA track day of the year down at Wild Horse Pass East. So at this point I was getting pretty stoked. Stay tuned to see if it pans out for my pathetic face.
