January 25, 2020, 05:50:00 PM
Author Topic: Rad shroud depth  (Read 482 times)
Offline Gunnytron
Rad shroud depth
« on: August 04, 2018, 02:12:07 PM »
I'm looking at making a shroud for my Hinson rad. What is the recommended distance the fan should sit from the radiator?
Re: Rad shroud depth
« Reply #1 on: August 04, 2018, 04:26:08 PM »
Generally you want to be about an inch or better.
Offline Gunnytron
« Reply #2 on: August 04, 2018, 04:36:04 PM »
Cool, thanks
