April 18, 2019, 03:03:08 PM
Author Topic: 17" wheel/tire specs  (Read 1126 times)
Offline Gunnytron
Re: 17" wheel/tire specs
« Reply #15 on: October 17, 2018, 03:27:16 AM »
Looking good. Don't forget to post more pics when the tyres are on 👍
« Reply #16 on: October 18, 2018, 09:10:09 PM »
You'll probably want to stick to 255 on a 9.5" rim. If you go too wide the tire can shift a lot and ruin turn in feel. I have a 255 in the front on a 10" and it's pretty awesome for the street. I think the Yoko ado8r's are a little wide for a 255 so it does my wheels very well. If you are going for maximum contact patch in the rear you can go wider but the rear can feel a little unsettled entering a corner.
Offline carlb
« Reply #17 on: October 18, 2018, 10:22:29 PM »
I'm running 245/40 on 17x8.5 +35 and 275/40 on 17x10 +40 Fiske wheels. I occasionally get rub in the rear, especially when carrying my linebacker sized son but rarely otherwise.
Sent from my SM-G955U using Tapatalk
Offline XcreatonX
« Reply #18 on: November 05, 2018, 12:30:16 AM »
I just ordered a set of 275/40s to see if I could fit them upfront, as they should not be an issue in the rears.  Based off the test fit, the 275s shouldn't be an issue in the front. Kind of wish I would of gone with a lower offset in the rear, just a little to sunk in for my liking.
Offline Gunnytron
« Reply #19 on: November 05, 2018, 02:39:24 AM »
Looks nice. Are you going to run wheel arch liners?
