August 22, 2019, 03:59:44 AM
Author Topic: Ronin RX-LS Swap Headers!  (Read 8496 times)
Re: Ronin RX-LS Swap Headers!
« Reply #45 on: July 29, 2018, 10:22:13 AM »
How close are the runner lengths? Doesn't look quite equal length from the photo but could just be the angle.
« Reply #46 on: July 29, 2018, 10:59:26 PM »
They're as close as we could reasonably package but to be honest equal length was only a secondary goal.  To quote David Vizard, equal length is far less important than the right length.  Case in point, perfectly identical equal length "3/4 length" headers just mean that none of the tubes will achieve pulse wave tuning.  In a properly designed long tube header, length is driven by the shock wave at exhaust valve open that heads down the primary at the speed of sound, then when it hits the first major change in cross sectional area the negative reflected pulse wave heads up stream.  You want to time this negative pressure front to occur at valve overlap.  However the math only works perfects for one length, one exhaust temperature, for one ideal RPM.  In practice we see a great deal of benefit over a range of RPMs since the shock wave has some duration to it.
The key point is that, yes equal length is nice to but it's not that big a deal if one runner is ideal at 5800 rpm while the one next to it is ideal at 6500 rpm.  But that would still be a 10% runner length difference.   However, if the shorter tube only comes into play at 8000 rpm, that doesn't work so well for our engines. The RIGHT length, that matters a great deal and that's where we spent our major effort.
Joel
« Reply #47 on: July 30, 2018, 02:41:42 AM »
Fair enough. If be curious if you could phase match the runners similarly to electrical length of RF cables. Meaning, as long as the length is in whole wavelength steps you get no interference.
« Reply #48 on: July 30, 2018, 05:55:09 AM »
Nice job joel.  Always good to see a set of headers with long runners.  Are you gonna dyno test these?
Offline Track_FC
« Reply #49 on: August 22, 2018, 05:51:02 PM »
Any updates on the headers?
Offline DailyDSM
  • In The Bleach Box
« Reply #50 on: August 23, 2018, 10:49:52 AM »
^What he said.  New engine is going back in my car in the next couple weeks and I've been dragging my feet a bit in order to time it with one of the prototype sets, if they will be available.
« Reply #51 on: August 28, 2018, 06:41:24 AM »
Seems like most folks are really interested in SS. Personally, I'm more interested in a mild steel(or stainless but $$$) ceramic coated version? I like the corrosion resistance of the SS but ceramic/mild steel seemed to do better with under hood heat and noise. The only downfall is under the car if you scrape off the coating like I did with my JTR's.
Oh and pics please!!!  :secret:
Offline 65imp
« Reply #52 on: August 30, 2018, 02:40:33 PM »
You guys will get pics when we have some to show.  Our new bender is installed, and we should be situated with appropriate dies for proper bends soon.  We went with slightly thicker Stainless pipe for longevity and reduced noise, but then we needed non-standard dies, and on and on.
Also Joel has interesting developments, but I will let him share.
93 FD widebody - destroked
65 Impala - 5.7
59 cad  - WIP
53 spartan - shed status
Offline staticx27
« Reply #53 on: August 30, 2018, 04:53:04 PM »
Depending on when these come out, I might even be down to prototype a set too ;)
Offline onefastrx7turbo
« Reply #54 on: October 04, 2018, 03:33:50 PM »
If you still need an FC for testing, I'm 100% in, tell me where to send the money!
2015 Nissan Leaf - DD
Past rides......
« Reply #55 on: October 09, 2018, 11:32:37 PM »
Thanks for your patience y'all.
Like many things sometimes you have to overcome the difficulties before you reach success.
In this case, I know I threw a pretty big wrench in the works with my new job and pending move to an island.   I haven't been able to sit down for a proper work session.  It's also been hard to get time on the bender.  Since setup took longer than they wanted (and they're still fighting heat issues with it) our shop has made a conscious choice to prioritize some easy but lucrative work over finishing up our R&D effort.  We get it, they went balls deep buying this thing and now it needs to make a return as quickly as possible...
I'm stoked folks are into these but it's going to take some more time before we get there.
« Reply #56 on: October 10, 2018, 12:14:21 PM »
All good, Joel! Life is what happens when you're busy planning things :)
Past rides......
« Reply #57 on: February 14, 2019, 02:50:03 AM »
Thanks for your patience.  I'm glad to report we have news, but I'll let the pictures do most of the talking.   :grin:
Really happy with the run and the layout.  We finally have damn good control over every bend and clocking rotation.  There are a few tweaks left to make but we're getting close now.  Even better, the shop we're working with just ordered a Romer arm with scanner so we're going to have ideal references to dial in the fit exactly how we want it.
We have another clamp die inbound to help us not have to squeeze the tube so hard while still avoiding slippage.
Anyways...  we're excited and hope you are too.
« Reply #58 on: February 14, 2019, 09:43:59 AM »
They look great! And on Valentine’s Day! You really know your way to our hearts.  😝
« Reply #59 on: February 14, 2019, 01:22:19 PM »
Are you planning one set for all three chassis? The pics look like an FC.
I'm curious how much ground clearance there will be.
