June 19, 2019, 12:01:59 PM
Author Topic: Esser's LS3 FD RX-7 R1  (Read 13274 times)
Offline Esser
Re: Esser's LS3 FD RX-7 R1
« Reply #30 on: December 05, 2017, 10:54:46 AM »
Mounted the lifting bracket to the valley, and started mating the engine to the trans. This took a little bit longer than anticipated, but after some will force I made the two go together.
Had some buddies come over to assist
Big grin on my face! this was a happy moment!
It's in!!!
Badass pic I took:
Offline Esser
« Reply #31 on: December 05, 2017, 12:06:18 PM »
intake installed:
Large amount of heat wrap on the fuel lines and clutch lines:
Trans mount fitted up:
Motor mount look really nice, tightened down the biscuits to get the engine height correct.
Shifter alignment, needed to cut the trans tunnel a bit. Went with MGW
Also started installing some accessories, picked up an alternator bracket and a nice power steering mount. I will be running Fbody accessories on the LS3.
« Reply #32 on: December 05, 2017, 02:25:31 PM »
So clean.  I love that I have working ABS but man I love the clean look of the ABS delete.  Stock LS3 intake fits hood/firewall just fine?
Offline Esser
« Reply #33 on: December 07, 2017, 12:32:51 PM »
Yes it clears with a 1/4" to the firewall lip. We will see about the hood lol.
Offline Esser
« Reply #34 on: December 07, 2017, 12:38:14 PM »
Starting fitting up the power steering pump. Since the Fbody power steering pump will over power the factory Mazda steering rack, I bought a Turnone pump reducer to try to get the flow to a more "light" feeling level.
Installed and lines ran:
I also mounted the extended clutch bleed line and mounted it to a bracket on the intake.
Shifter hole block-off black installed and knob fitted. Went with a C6 shift knob, should look factory-like!
Offline Esser
« Reply #35 on: December 07, 2017, 12:43:15 PM »
Filled the power steering system with Driven oils power steering Fluid:
Will be using an Odyssey PC925 battery, and fitting it under the bin behind the passenger seat.
Offline 7th Heaven
« Reply #36 on: December 09, 2017, 05:36:07 PM »
Coming together nicely
Want a FD/FC A/C wire harness? Message me if in need!!  :cheers:
Offline Esser
« Reply #37 on: December 12, 2017, 03:32:11 PM »
Made my own wire terminals for battery relocation.
Started wiring in the engine. I went with the PSI conversions wire harness. Quality seems spot on and price is great compared to all other harness manufacturers. I 3D printed a hole size reducer so that the 2inch firewall grommet on the harness would mate up to the existing 3inch hole on the FD firewall.
Heat wrap installed:
I was also able to get the samberg radiator installed:
« Reply #38 on: December 12, 2017, 11:44:58 PM »
Looks great, I dig the 3D printed piece.
Offline radiomike
« Reply #39 on: December 13, 2017, 06:48:04 AM »
Have you checked the clearance between the IR strut bar and the crossover fuel pipe, ours was zero?
Offline Esser
« Reply #40 on: December 13, 2017, 11:36:27 AM »
My fuel cross over happens after the strut bar, and the strut bar clears the intake by about 1/4". Your engine may be a bit too far forward? I can get more pics of mine if needed.
« Reply #41 on: December 13, 2017, 11:49:16 AM »
I had to clearance my strut bar as well with a factory LS3 intake.  It bolted down seemingly fine until I saw the interference.  There was about a 1/4" that needed to be relieved.
« Reply #42 on: December 13, 2017, 11:53:37 AM »
I had to do the same.  Ground a little crescent out of the bottom to match the intake
Offline radiomike
« Reply #43 on: December 13, 2017, 11:56:12 AM »
The only difference I can see is you have the Samberg fabricated engine mounts in place of the C5 ones, perhaps the offset is different.
« Reply #44 on: December 13, 2017, 09:56:33 PM »
I have the aluminum Corvette mounts, and had to similarly clearance my brace as well.
