January 17, 2019, 11:01:56 PM
Author Topic: Esser's LS3 FD RX-7 R1  (Read 10573 times)
Online MPbdy
Re: Esser's LS3 FD RX-7 R1
« Reply #165 on: January 02, 2019, 04:36:36 PM »
Those slicks and skinnies worked like a charm!  Is that a 1.65 sixty?  The slip is a little blurry.  On a dynojet I'd put you around 480whp.  Nicely done!
My best on street tires driving off the line is a 1.76 sixty and 11.19 and I'm at 465/450.
« Reply #166 on: January 02, 2019, 04:43:21 PM »
That's fast, congrats!  I was trapping 127 with 475 RWHP.  My car is kinda a pig though.... needs to go on a diet.
I should rent those slicks from you to see if i can get low 11's...
Offline JustJewIt
« Reply #167 on: January 14, 2019, 01:33:05 PM »
Car looks great man. Mind sharing the specs on your Weld/Hoosier setup? Did you have to grind down brake calipers to get them to fit? I know many have had to do that due to clearance issues. If this is in the thread already, my bad.
ROTORLS
Offline sonicgroove
« Reply #168 on: January 14, 2019, 03:39:50 PM »
Sorry about this random post in your thread, esser, but I had chime in regarding the previous users name, LOL! I love it and going to mention it to my jewish friend. She'll get a kick out of it.
-groovin
Offline Esser
« Reply #169 on: January 16, 2019, 11:18:53 AM »
Thanks, I didnt have to grind any brake calipers, just had to use a socket cap screw on the trailing arm.
Specs are:
15x9.5 6.5bs"
15x4.5 2.5bs" (with 8mm spacer)
This is ideal fitment for rolled fenders
Tires are 25x5 fronts and 26x11.5 Hoosier QTP's. They grip amazingly on the strip, I would bog from a 5k clutch dump
