Do you have any info or pics of the rear over fender installation?or if ppl are molding them in, how they went about doing so?
Here's the rear fender's bare during a test fit session.
Here's the molding in process as done on my FC with the tri point kit (overall work starts in post 148):
http://www.norotors.com/index.php?topic=1274.msg18457#msg18457Short version of the molded in version:
-Test fit with cleckos or sheet metal screws.
-Cut fender and liner to clear, add close out sheet metal if desired
-Remove paint from bonding area and clean
-Bond on w/ 3M panel bond
-Blend in w/ kitty hair followed by standard filler.
Fit on these guys is good enough you could rivet and call it a day if you're in race car mode (you still want to trim fenders for tire uptravel though)
