January 22, 2020, 08:36:35 AM
Author Topic: New Aero Rice  (Read 4845 times)
Offline Kevin Doe
New Aero Rice
« on: September 04, 2016, 09:17:34 PM »
Started here....
Wing by Kevin, on Flickr
Bumper done...
Then mocking up some designs for uprights.
Finalizing the design in CAD.
Some FEA work.  This is with downforce and drag load (max AOA, 160 MPH, 1.5x on loads for factor of safety)
Side load added in. 3Gs x 1.5.
Lateral Deflection from side loads (which equated to ~75 lbs).
Brackets waterjetted out of 3/8" 7075-T651 plate.  Then roundovers added with a wood router with a carbide bit.
Powdered...
And done...
Steamroller
Re: New Aero Rice
« Reply #1 on: September 04, 2016, 10:00:08 PM »
Seems like it's been awhile! Looks great. I remember the thread on forum doing a similar design but it mounted below the rear bumper.
Offline Ebush
Re: New Aero Rice
« Reply #2 on: September 05, 2016, 01:19:31 AM »
Looks great! Hope to see the car around at some local events. Been a few years since I've seen it anywhere.
Re: New Aero Rice
« Reply #3 on: September 05, 2016, 12:26:03 PM »
Great engineering and workmanship, but yeah, very ricey.   :poke:
Offline tai-lun
Re: New Aero Rice
« Reply #4 on: September 06, 2016, 01:27:56 AM »
I am a fan of this functional rice, and may even be joining the big wing brigade one day too.
Looking forward to hearing about differences post wing, fantastic fab work as always. Is it a GT300 or GT500 from APR?
Build Thread: https://www.norotors.com/index.php?topic=9172.150
Offline Kevin Doe
Re: New Aero Rice
« Reply #5 on: September 06, 2016, 09:10:54 AM »
Thanks guys. It is an APR GTC-300
Steamroller
Offline Supe
Re: New Aero Rice
« Reply #6 on: September 06, 2016, 09:44:41 AM »
Very nice!  I need to do something similar.  My current setup is way too draggy.
Offline sunshine
Re: New Aero Rice
« Reply #7 on: September 06, 2016, 05:31:26 PM »
looks really good!
props man!! you should consider producing/selling this setup.
Re: New Aero Rice
« Reply #8 on: September 06, 2016, 05:43:17 PM »
Nice work. Now you should make a rear diffuser.
Offline markfluko
Re: New Aero Rice
« Reply #9 on: September 06, 2016, 06:15:23 PM »
Always good to see a post from Kevin!
Any post on the front splitter build?
I have the same wing... and now our cars look nearly identical - mine being the neglected step child.  :cheers: I may beg you for the CAD file because I DO NOT like the way the APR mounts fit on the hatch... also I want to go with a CF hatch and don't want to drill into it.
IIRC you run mostly autox, and I believe the rules for XP don't allow for any part of the wing to go beyond the rear of the car.
"In addition, no portion of the wing or its components may be more than 6 (15.24 cm) forward
of the rear axle, more than 0 (0.0 mm) beyond the rearmost portion of the bodywork"
Also looks like your splitter might be too wide also...
"No portion of the splitter may extend beyond the widest part of the front bumper as viewed from above."
http://cdn.growassets.net/user_files/scca/downloads/000/017/206/2016-8-23_Appendix_A.pdf?1471970139
Not hatin', just want to make sure you know in case you decide to make the trip to Lincoln!
Offline AKINA FC
Re: New Aero Rice
« Reply #10 on: September 07, 2016, 12:16:13 PM »
Very nice work Kevin  :cheers: I need to get around to mounting my new foil as well.
[smg id=6531]
Re: New Aero Rice
« Reply #11 on: September 09, 2016, 01:54:50 PM »
Let us know how it works out this weekend.   I believe you are going to a mixed event with AutoX, drag, and something else ;)
Re: New Aero Rice
« Reply #12 on: September 09, 2016, 04:43:34 PM »
Nice fab Kevin!
Questions:
-Any tips or trick on using a roundover bit in a wood router?  I'm going to try that.
-Can you open your hatch?  On an FC it's not even close, at least if you try to align to Autocross rules about zero overhang that is.
-Any reason you didn't go bigger with the lightening holes?  FEA looks like the only hot spots are hardware.  What did you decide on for your pass/fail criteria?
Regards,
Joel
PS what's the event?  Car's looking great.  Good luck to you!
« Last Edit: September 09, 2016, 04:52:31 PM by frijolee »
Offline Kevin Doe
Re: New Aero Rice
« Reply #13 on: September 11, 2016, 10:46:51 PM »
The even was LS Fest this past weekend, in Bowling Green KY.  I was there, but unfortunately my tires never came in (ordered Jun 1st).  The BFG Rival S's are impossible to get last in the season, so I was just a spectator.
The wing mounting won't pass SCCA XP rules, it is about 1.5 or 2" past the rear of the bumper.  I don't really care to compete in SCCA competitively anymore, so I didn't pay too much attention to meeting those rules.  I'm planning on doing some more of the Pro Touring events like the Optima Events, and Midwest Muscle Car challenge, Northeast Muscle Car challenge, LS Fest, etc. I will be changing the car's setup to work with a 200 TW tire, so that will be fun.
Tips on the routing.  Use a lot of lube.  Cutting dry with a carbide bit left the surface marred looking.  I doused it in WD-40, and all was well cutting after that.  Also, i think the lowest setting on my router is 8k rpm, which seemed too high based on what I was calculating for surface speed, but it worked really well.
As far as lightening holes, the bending stiffness is what was really limiting.  I was trying to keep under 1/4" deflection laterally.  After having it on the car, and pushing around on the wing, it is VERY stiff.  I probably could have went more aggressive with the lightening, but it would only have saved a few ounces.
Splitter build.  I was really slacking on taking any pics.  I'll give a really quick run down.  I overkilled it, its too heavy, and stupid stiff.  I'll be making another, probably this winter.  I did 7 plys, core, 7 plys.  I could stand on it before I installed the front struts.  I'll probably go 4 core 4.  I would probably get away with 2 core 2 for stiffness, but for impact (cones), I'm thinking I'd like the leading edge to be close to 0.1" thick or so of solid composite.
Steamroller
Offline Kevin Doe
Re: New Aero Rice
« Reply #14 on: September 11, 2016, 10:48:27 PM »
And anyone that wants the CAD files for the uprights just let me know where to email them to.  I can send as a .prt for NX, or export in any format you want.  I have .dxf formats already done for water jetting too.
Steamroller
