February 18, 2019, 04:49:16 AM
Author Topic: Kingers Garage  (Read 20660 times)
Re: Kingers Garage
« Reply #285 on: January 29, 2019, 03:18:04 PM »
hey buddy question. How accurate is your fuel speed hut gauge. I'm pretty sure mine is off. Would you happen to know which setting you put it on to make it work with our stock sending unit unless you got something else different
Ahh the fuel gauge...
Iím not real happy with the gauge, it does work but it stays on Full for a long time, then slowly drops to half over about a 20 mile period.  Then the last half of the tank can drop in 5 miles to empty.  Go to fill it up and there was 3-4 gallons left.   So I have gotten in a habit of filling at 1/2 tank.  It used to be erratic and a better ground fixed that issue, but still using the stock sender it seems to be a little less then perfect vs a OEM set up.  Good enough to use and trust but just not perfect which is how I want everything :).
I did double check the settings when I was chasing the ground issue and Halfspec did have it set up right.  I think I also email Speedhut to confirm but I canít remember the exact settings.
Good luck!
Sent from my iPad using Tapatalk
Offline halfspec
  • Resistance Is Futile
    • HalfSpec.com
Re: Kingers Garage
« Reply #286 on: January 29, 2019, 04:01:04 PM »
For the FD's sender, it's supposed to be ~ 7 ohms full, 76 ohms empty.  With a speedhut gauge, you put it in programming mode and either connect the sender and cycle between the empty and full positions, while telling the gauge which position you're in, OR you connect 7 and 76ohms of resistance to the wiring respectively and tell the gauge which is which. I think I did it with a multi-turn 0-100ohm potentiometer and a multimeter, as I had a hard time trusting the sender.
FD's have a really exposed sender / potentiometer and I can't imagine it's completely inert to gasoline, so after 26 years, some start to not read so good ;)
At least that's been my experience / observations.
On the other side of the coin, from what I've seen and heard over the past decade, it appears Speedhut has had some quality control issues here and there so I wouldn't put too much trust in the gauge either.
Lane
Offline AV8rZ
Re: Kingers Garage
« Reply #287 on: February 04, 2019, 12:08:39 PM »
Lane
I knew you would come out of hiding one of these dayz
