January 25, 2020, 06:05:37 PM
Author Topic: Adapting a BMW ZF trans to an Audi AAN 20V turbo.  (Read 3647 times)
Offline ilovemybike
« on: May 08, 2016, 09:23:10 AM »
I have been helping a friend with his 242 Volvo build, its going to run an AAN Audi engine and be a track/drift car.  I started on the build by modifying his intake manifold from side throttle body to front to fit between the Volvo strut towers.  Later he had me make a rear sump pan to fit over the rack. Because the Audi motor comes in AWD platforms only there aren't many RWD transmission options.  He comes from a BMW background so he was interested in running a ZF five speed. As a small, lightweight, fairly rugged transmission with a low street price, it fit the bill. In order to adapt it to the engine I cut the transmission using a combination of cutoff wheel and my lathe.  Because the transmission is so off balance on the lathe I spun it by hand to face the cut after using a cutoff wheel.  Volvo used VW diesels in some of their cars and my friend had sourced a bellhousing from one that bolted up the AAN engine.  I used my mill to shorten it and reach the desired depth of the input shaft.  I decided to base the distance from the engine based on the input shaft in the pilot bushing, which I made from bronze for the swap.  With the input shaft an 1/8" from bottoming on the bushing the splines were fully engaged with the clutch disk and the throwout bearing was nicely placed with the pressure plate. Cast alloy welds great.
86 Comanche LM7 Prerunnerish
88 RX7 LM7 T56 Ronin 8.8 IRS
84 Mercedes 300D Circle track coilovers
85 Merkur XR4Ti M50 HX35 big tires
Re: Adapting a BMW ZF trans to an Audi AAN 20V turbo.
« Reply #1 on: May 08, 2016, 10:32:55 AM »
Love it  :D
« Reply #2 on: May 08, 2016, 10:36:10 AM »
Cool project!
« Reply #3 on: May 09, 2016, 10:11:17 AM »
sweet! You always have the most interesting projects.
« Reply #4 on: May 15, 2016, 08:30:43 PM »
nicely done!
Offline ilovemybike
« Reply #5 on: May 16, 2016, 09:09:39 PM »
Thanks guys!  :cheers: It was a fun little project. Now I understand how all the Scandinavians get away with their weird engine and trans combos.  It seems like every Gatebil car has some odd ball setup that was welded together in the depths of a dark winter.
Offline ilovemybike
« Reply #6 on: October 10, 2018, 08:04:29 PM »
<img src="https://www.norotors.com/gallery/947-101018200151.jpeg" />
This car is about to run, pretty neat setup.  I made the turbo manifold, did all the intake plumbing, the catch can, intake manifold, the bell mouth for the throttle body blow off valve, the oil pan, and the transmission adaptation of course.
Offline BlackEuropa
« Reply #7 on: November 17, 2018, 12:50:48 AM »
Nice work.
I used to play with a boosted Quattro track car. That motor is a tough beast!
Offline shainiac
« Reply #8 on: November 19, 2018, 10:14:44 AM »
Is that a DBW blow off valve? What's the logic behind that?
Also, what are you using for engine management?
716whp/662wtq @1.3bar
Offline gc3
« Reply #9 on: November 19, 2018, 01:13:31 PM »
thats awesome
Offline screamin88
« Reply #10 on: November 20, 2018, 07:51:35 AM »
 :afro:
HECK YA!
« Reply #11 on: November 29, 2018, 11:47:11 AM »
That is a clean swap!  We need video dammit.
« Reply #12 on: December 03, 2018, 10:08:55 PM »
Is that one of the motors that sounds like half a v10? Like the new RS3.
94 BB SBE LS1 Full Mamo top, MS3ProU with TC, RONIN 8.8 and another custom dual 2.5" stainless exhaust. Not too loud with the new resonators!
Offline ilovemybike
« Reply #13 on: December 18, 2018, 06:35:14 AM »
:afro:
HECK YA!
  :cheers:
. They sound like group B rally Audiís
When it gets on the dyno I will post a video
thats awesome
:cheers:
The owner works at ACE performance and they have an Emtron representative that tunes their cars, theyíre going to use this as an example of what their system can do. There are three pressure sensors on the boost side, pre intercooler, post intercooler and intake manifold. The tuner likes the DBW throttle body setup and the three sensor layout for boost control. There is an exhaust back pressure sensor and a bunch of funky stuff going on. I havenít got the chance to talk to the tuner about this setup but I am curious to see how it works
