January 17, 2019, 05:08:51 PM
Author Topic: Samberg radiator kit in fd, hood won't close?  (Read 2257 times)
Offline atl
« on: February 04, 2016, 02:18:31 PM »
So I have a samberg radiator kit in my fd and the hood won't close when you attach the couplers from the air filter to the maf, to the throttle body.  The part that is making contact with the hood is the 90 degree coupler(pre-maf after the air filter).  And there isn't any more material to remove from the hood, without there being a hole in my hood.
So do I have the wrong parts? Am I missing something? I don't need a hood right? Kidding I need a hood.
Offline atl
Re: Samberg radiator kit in fd, hood won't close?
« Reply #1 on: February 04, 2016, 02:19:06 PM »
Offline atl
« Reply #2 on: February 04, 2016, 02:23:16 PM »
Electrical tape on hood is where the 90 degree coupler is making contact
Offline Mysta Joe
« Reply #3 on: February 04, 2016, 04:39:30 PM »
try loosening the bolts that hold the hood latch and slide it up as high as possible and tighten back, see if that gives you the clearance needed.
Offline Still_Ridin_Clean
« Reply #4 on: February 05, 2016, 02:29:28 PM »
I bought silicone couplers and it fixed the problem. I didnt have to notch the hood. I'll post a few pics in a little bit.
Offline atl
« Reply #5 on: February 06, 2016, 12:03:09 AM »
thanks man, cool of you to do that.
Offline wtfx100
« Reply #6 on: February 07, 2016, 01:22:19 AM »
Ditch the hardware store plumbing and your good to go.
Offline atl
« Reply #7 on: February 07, 2016, 01:33:14 PM »
The "hardware store plumbing" is what samberg sent in there radiator kit.
Offline Nfinitecc
« Reply #8 on: March 15, 2016, 12:19:39 AM »
You probably fixed it by now but I had to shave the couplers and there are actually 2 layers of sheet still where your hitting that you can remove from the hood, after I did all that I have a hairs width gap.
Offline dvo
« Reply #9 on: April 22, 2016, 12:11:56 PM »
do you have part#s and/or links for the couplers you used?
