Lane,
I was looking at the diagram, and even if the PCM output opens, there was still another path through D2 and the compressor relay coil, back to sw12v, and all the other loads attached to that. I doubt the one relay would pass enough current to pull in the fan relays, but it could slowly drain the battery.
Feeding all the relay coils with sw12v should eliminate that possibility as well.
No. That section of the circuit only deals with grounds. In fact, in my diagram the bottom side of the coils / Pin 85 is the ground side of all the relays for the sake of consistency. The top side / pin 86 is the only side that reacts to 12v. Feeding 12v to any pin 85 in my diagram wouldn't do a thing, since pin 86 would already have 12v on it and you'd have 0v of potential across the coil.
Respectfully, I think you're mixed up about the operation.
There are three states where the fan relay output gets a ground.
State 1 - The PCM orders low speed output due to hot coolant temps. Notice the polarity of D2 stops the AC compressor relay from receiving a ground.
State 2 - The RPM window switch is within its 'RPM window' and hence delivers a ground to pin 30 of the AC signal relay, while concurrently, the AC button is pressed, which gives a ground to pin 85 of the AC signal relay latching 30 to 87 and allowing the ground to activate the compressor relay. Note D3 stops the PCM's low speed fan output from receiving an external ground (gets you a MIL light and a fault code).
State 3 - States 1 and 2 occur simultaneously:
States 2 and 3 are where you can run into a problem with the LS PCM sending a ground to the Fan Relay output and keeping the radiator fans on even after the PCM loses power and they stay on until the coolant temps come down below the low setpoint. Delete the whole rest of the AC circuit and the LS PCM fan outputs still behave this way.
The original LSX AC circuit posted in this thread had the benefit of being endlessly bench tested on my own FD and after that, went out to ~50 of my own customers before I posted it here. Rob's diagrams were turned out in a few minutes while my kids were probably screaming at me
Lane
