April 26, 2019, 04:13:05 AM
Author Topic: Adjustable bumpsteer kit - FD tie rod end taper size?  (Read 2822 times)
  • I steer with the gas pedal.
Re: Adjustable bumpsteer kit - FD tie rod end taper size?
« Reply #15 on: December 14, 2015, 09:12:55 PM »
So the shank diameter is OK for the FD?
Offline Sketch_hs
« Reply #16 on: December 15, 2015, 11:02:21 AM »
I attempted to install mine the other day when I replacing my bushings.
I noticed they will not fit my 17' wheels.
They do not give the samberg helm joints full range of motion unless a tapered spacer is installed on both sides of the joint.
Yeah you'll want these:
http://www.speedwaymotors.com/Steel-Cone-Spacers-for-Rod-Ends-5-8-Inch,32702.html
They were pretty close already on my 18s, so for 17s you'll need to cut them down
Offline Sketch_hs
« Reply #17 on: December 15, 2015, 11:03:33 AM »
So is this an alternative to the samberg or you saying these are better ? Did you not use the samberg for a certain reason?
This is so you can adjust the bump steer out - the samberg kit is fixed!
Offline ls3_rob
« Reply #18 on: December 15, 2015, 12:33:45 PM »
could you post a picture. I am having a hard time understanding how these are installed
07 tl type s daily
93 rx7 ls3
Offline Sketch_hs
« Reply #19 on: December 15, 2015, 03:55:18 PM »
They just replace the non adjustable part from the samberg kit. You still need everything else! :yay:
« Last Edit: December 17, 2015, 06:08:24 PM by Sketch_hs »
« Reply #20 on: December 19, 2015, 03:16:33 AM »
Are you guys needing to shorten the tierod spacer that Samberg supplies to correct the bump-steer?
I hope so, because I have absolutely no clearance to lengthen mine, and there's only about 1/8" I can space up the rack.
I haven't actually measured bump steer on mine, but it sure feels like it.
Even after setting the alignment, the car still darts around on a bumpy road, and wants to follow ruts as well.
My front tires do have bad camber wear, the outside is worn out and they still have probably 1/2 tread depth on the inner edges, so I'm sure that's not helping any. (Looks like the camber-cut tires on my racecar, LOL)
New tires are on the short list, by the way.
David
« Reply #21 on: January 04, 2016, 12:08:37 AM »
I spaced my rack up .120" (all the space I have) and reset toe back to 1/8" out.
It made a major improvement, even with the old tires.
The car is much more stable over bumps now, but I still get a LOT of feedback through the depowered rack (not a totally bad thing), and it still follows ruts like mad.  :o
I'm holding off buying tires because I haven't decided on sticking with the 17's or switching to 18's.  Tire selection in 17" is getting pretty limited, but I really dislike extreme low profile tires, and I love the period look of the Blitz Type-03's.
Any suggestions on a lightweight 18" wheel, along with the width and offsets to get the most tire under the car with nothing more than rolled fender lips, would be appreciated.  :cheers:
Thanks,
David
Offline BeasTT
  • Twinz for teh winz
« Reply #23 on: April 05, 2016, 10:27:56 PM »
Bump for updates
Nick Shultz
1993 Rx-7
Offline Cryptic
« Reply #24 on: April 12, 2019, 01:40:38 AM »
Anybody have a picture of this installed?  Trying to understand how to this replaces or is used with Samberg's bump steer. I dont get it. Am I looking at the right thing? Is this like a taller spacer?
https://www.speedwaymotors.com/Pinto-Spindle-Bump-Steer-Correction-Kit,52425.html
I'm assuming we disassemble this tie rod end and replace with the above???
1995 427 LS3 Burnout Widebody FD
My build thread
2011 Ford F250 CCSB 6.7L
« Reply #25 on: April 12, 2019, 09:01:52 AM »
That's not the right speedway pinto item above.
Here is a pic. I cut the length after I got the bump steer dialed in.
I should mention, I have ccw's and most of their wheels have a 17" barrel. Even on the 18's. Including mine. I've had them in for over 2 years now.
Offline Cryptic
« Reply #26 on: April 12, 2019, 04:58:16 PM »
Did you need the cone spacers like someone mentioned above?
What method did you use to adjust the bump steer? Did you have one of those Longacre tools like this:
« Last Edit: April 12, 2019, 05:04:03 PM by Cryptic »
My build thread
« Reply #27 on: April 13, 2019, 01:56:30 AM »
I did not use the spacers. Don't seem to have any issues. I don't think the full range of the joint is necessary on the Rx.
I did it the way bad obsession Motorsports did it on Binky. A laser and a piece of paper to mark the movements.
