August 19, 2019, 07:11:37 PM
Author Topic: Subframe Camber/Caster Guides  (Read 1779 times)
Offline neil_se
« on: October 27, 2015, 05:33:59 PM »
I've bought an unfinished project that came with a Samberg crossmember already mounted. When I look online at pictures of the subframe there's guides for the new larger camber & caster washers on both sides of the mounts (as circled in white below) whereas mine only has the ring/guide on 1 side of each mount. I also don't have the washer marked 'weld' in the image below, only the bottom section.
Was this something that was changed on later versions because there was alignment problems?
Offline neil_se
Re: Subframe Camber/Caster Guides
« Reply #1 on: October 31, 2015, 11:09:40 PM »
No one knows?
« Reply #2 on: November 01, 2015, 12:51:02 PM »
Yes, it was revised for version 2.
