For crawling I think converter selection is going to be pretty critical. I suppose you don't need a ton of torque multiplication since you have many ranges and tons of mechanical advantage. 1800 stall speed will be plenty to get the engine into a usable powerband with a smaller cam. I don't know if a higher stall converter like 2500-2800 with a lot of torque multiplication would be detrimental for crawling, but would make a huge difference in acceleration.
Trying out the stock converter you have should be just fine. I'd consult with converter shops who specialize in offroad/crawling builds if you ever decide to get something else. The converter is one of the most critical components in making a package come together. Sort of like...the camshaft of the transmission if that makes sense.
Regarding intake runner volume - I see that 91% isopropyl IS .786 g/cc which gives basically a 280cc intake runner which makes sense. Stock intake runner volume is 260cc for an LS3/L92 head. 280cc is pretty damn big which is a criticism of ported LS3 heads. Since they start at 260cc already the only place to go is from big to huge. Won't really hurt anything, but with a small cam and LS3 intake you won't really be utilizing the large port. The good thing here is that you have a stroker crank which does put more demand on the heads and the bigger runners will help support that.
https://www.noco.com/documents/ISOPROPYL%20ALCOHOL%2091.pdfBlower cams have large splits because they have a denser intake charge - you cram way more air in through in a shorter duration. The exhaust needs to be open both early enough and long enough to evacuate everything without stalling out at higher RPM. Because the air is being forced in you don't need to rely on overlap to make power compared to an NA engine which needs the engine to scavenge through the exhaust. That points to the other defining characteristic of a blower cam which is a wide lobe separation angle. This both keeps overlap at a minimum and opens the exhaust valve sooner to help evacuate the cylinder.
LS3 heads are pretty out of balance when looking at the intake/exhaust flow ratio. Because of the big intake valve and large port a ton of air can come in. You crutch the weaker-by-relation exhaust by keeping it open longer.
Factory LS cams all have anywhere from 6 to 20 degrees of split between the intake and exhaust lobe, so 10 degrees is not out of the question.
