August 21, 2019, 05:19:25 AM
Author Topic: 1993 Volvo 945 L33  (Read 20860 times)
Offline rallydallas
Re: 1993 Volvo 945 L33
« Reply #30 on: April 29, 2015, 06:10:01 PM »
Got some materials in today.
Vibrant 10359:
Flowmaster 13516100:
Vibrant 1153:
Columbia River Mandrel tubing:
Offline rallydallas
« Reply #31 on: May 14, 2015, 04:54:47 PM »
Got the throttle done:
Believe it or not, that 36" Lokar TC-1000LS1 kit fit perfectly.  Just had to trim the extra cable from the throttle body side so that the clip would fit.  Also manually tested the throw of the foot pedal and it appears to be 100% of the throttle body throw.
« Last Edit: November 07, 2016, 07:33:31 AM by rallydallas »
Offline rallydallas
« Reply #32 on: August 29, 2015, 06:42:57 PM »
Working on the accessory drive.  I'll probably redo all of it in the future.
Offline rallydallas
« Reply #33 on: September 13, 2015, 04:35:31 PM »
Ok, so today it started!!!    8)
Offline rallydallas
« Reply #34 on: September 28, 2015, 12:10:49 AM »
I made an attempt at the power steering mount and also I have a manual tensioner now.  Tensioner is probably going to have to be re-worked but the pump mounting is pretty well aligned, believe it or not!  I just used mild steel for everything so I'm considering this v0.1; at some point I'll try and come up with cad designs for some AL replacement mounting!
« Last Edit: November 07, 2016, 07:33:44 AM by rallydallas »
« Reply #35 on: September 28, 2015, 08:20:20 AM »
That looks plenty beefy on that mount!
Offline rallydallas
« Reply #36 on: September 29, 2015, 10:44:37 PM »
Got some belts yesterday and today, but they are proving to me that I'm definitely going to have to spend some time fine tuning the belt drive.
That belt is a K060966 (96.6 inches or 97-1/8" / 2468mm).  I might have to go with the 1 inch smaller one, K060956 long-term.  I'm going to have to re-position the PS to Alternator idler for sure which should get me better access to the tensioner amongst other things.  All of the mounting needs more bracing because they flex a lot right now!   :-[
« Last Edit: November 07, 2016, 07:33:57 AM by rallydallas »
« Reply #37 on: September 29, 2015, 10:49:20 PM »
Wrap and layout looks good.
Offline rallydallas
« Reply #38 on: October 04, 2015, 05:01:01 PM »
Finally removed the LH2.4 engine bay harness.
Offline rallydallas
« Reply #39 on: October 05, 2015, 11:01:30 PM »
Driveshaft
Driveshaft Specialist Inc.
8327 McCullough Avenue
San Antonio, TX  78216
210-342-6622
http://www.driveshaftspecialist.com
« Last Edit: November 07, 2016, 07:37:41 AM by rallydallas »
Offline rallydallas
« Reply #40 on: October 10, 2015, 01:29:06 AM »
Got a lot of wiring done tonight. Transmission is wired up.  Starter is wired.  Tach is wired.  Chassis is connected to the battery now.  Still have a bit more wiring to do before I can turn the key though.
« Reply #41 on: October 10, 2015, 08:11:30 AM »
Looks like a pretty tight fit with all that stuff in there.
Offline rallydallas
« Reply #42 on: October 13, 2015, 08:44:21 AM »
Yah, the engine is definitely "high and forward" due to the fact I haven't cut the front crossmember.  At some point in the future I'd like to get a fully fabbed crossmember that would let me move it down and back.  Right now it sits about 1/2" above the stock crossmember at the oil pan and is limited moving back due to it being high up.  Everything does fit in there, though, without hitting the hood so far.
Offline rallydallas
« Reply #43 on: October 13, 2015, 02:44:19 PM »
Here's a pic of some of the wiring work I did this past weekend.  This is pretty much the only cut of the stock harness I did--I installed a ground connection for the fuel pump relay.  The Yellow/Black wire normally gets grounding from the Bosch ECU, but I've modified it to be hardwired to ground, while the Blue/Yellow gets power from the GM PCM.
« Reply #44 on: October 13, 2015, 08:22:12 PM »
That looks nice and clean.    Good wiring is key to a sound swap.
