April 24, 2019, 04:39:28 AM
Author Topic: 1993 Volvo 945 L33  (Read 18995 times)
Offline rallydallas
Re: 1993 Volvo 945 L33
« Reply #15 on: January 15, 2015, 11:50:14 PM »
Got the McLeod 139204-36 clutch line in today.
McLeod 139204-36 clutch line and its box:
« Last Edit: January 19, 2015, 05:50:43 PM by rallydallas »
Offline rallydallas
« Reply #16 on: January 19, 2015, 11:47:25 AM »
Not sure if I'm going to stick with the 36" or not.  When I got it on, it actually looked like it was almost exactly 6" too long.  I might just re-route it to take up the slack.
Offline rallydallas
« Reply #17 on: January 19, 2015, 05:50:05 PM »
Got the alternator handled.  Stock 1993 Volvo 940 alternator converted to 6-rib.
Stock alternator with pulley and nut removed:
Back of the stock alternator:
Corvette pulley (Gates 37009P) and tool (Alternator Decoupler Pulley Service Kit 27275):
Corvette pulley attached:
For reference, the Volvo alternator shaft is 17mm, the nut is 15/16".  The inner part of the shaft is 12-tooth.  The inner part of the Corvette pulley is 33-tooth.
Offline rallydallas
« Reply #18 on: January 23, 2015, 12:00:16 PM »
Did some work at the Dallas Makerspace last night.  My first attempt at motor mounts.
On the plasma cutter:
Results:
Original design:
Still have to clean them up, cut square tubing, weld, and maybe get plated (probably).
Offline LSXREX
« Reply #19 on: January 24, 2015, 11:05:41 PM »
is that you staring at the cutter?
2004 LS1/T56 swapped RX8
RX8Club is for pussies
« Reply #20 on: January 25, 2015, 10:14:06 AM »
Pretty neat, I have a buddy with a plasma CNC table, I need to get him to make me some stuff.
2013 Focus ST3 - Stage 1 BPU
Offline rallydallas
« Reply #21 on: January 25, 2015, 02:16:23 PM »
No, that's one of the board members of the space.  He's often there.  I really love the Plasma CNC, but getting the old software we have to work with what I have is not simple.  We're still working on the workflow for that though.
Offline rallydallas
« Reply #22 on: January 25, 2015, 02:19:25 PM »
I plan on having the files out there with Open Source Hardware licensing, I just haven't decided where to put it yet exactly.   :yay:
The same for my trans mount and the accessory drive parts.  I'm still thinking about the design for those while I'm working on these mounts.
Offline rallydallas
« Reply #23 on: January 25, 2015, 07:38:49 PM »
Worked on the power steering pump today.  Installed a Dorman 300-302 pulley.
Pulley on the pump:
For reference, the dimensions on that pulley are:
6 groove
0.66 in (~17mm) inner diameter
Snout offset in from front edge 4.5mm
Snout offset in from rear edge 2mm
Circumference of grooved area 41cm (13.05 diameter)
Outer edge diameter 13.5cm (42.41cm circumference)
Offline rallydallas
« Reply #24 on: January 26, 2015, 07:59:00 AM »
Forgot to add, for reference, used the good 'ole "OEM/Pulley puller installer kit  Part Number: 27031", with the 3/8" x 16 bolt on the shaft.
Offline rallydallas
« Reply #25 on: February 08, 2015, 12:02:29 AM »
Did some MIG'ing at the Makerspace today.  Pretty newb welds, but they should be sufficient.
Welded engine mount:
Offline rallydallas
« Reply #26 on: April 12, 2015, 11:35:29 PM »
Got some krap done this weekend.
Half my coolant hoses:
(upper is MBH 22373, lower is Gates 22437 modified)
Transmission mount (looks like I'm going to have to grind one side a bit though, so not finished...):
Shifter:
« Last Edit: August 25, 2015, 05:05:17 PM by rallydallas »
« Reply #27 on: April 13, 2015, 08:24:15 AM »
Coming right along.
Offline rallydallas
« Reply #28 on: April 19, 2015, 02:21:13 AM »
Manifolds:
Offline rallydallas
« Reply #29 on: April 21, 2015, 09:03:52 PM »
Transmission crossmember:
Fitment of driver side manifold @ steering column:
Now on to other stuff...
« Last Edit: April 21, 2015, 09:56:15 PM by rallydallas »
