July 16, 2019, 04:04:50 AM
Author Topic: Hinson radiator clearance hood  (Read 1383 times)
Offline johnnywynnz
« on: August 24, 2014, 04:08:40 PM »
Does anyone know how to clear the radiator and the closure if the hood. Mime seems  to have problems clearing the radiator cap. It hits at that part.
Any feedback. I have already lowered the side of the radiator using rubber washers on bottom mount. But that's just a quick fix. My plate cover  now doesnt bolt up.
Offline Hinson Motorsports
  • Pre-Staging
  • Engine Conversion and LSx Specialists
    • Hinson Motorsports
Re: Hinson radiator clearance hood
« Reply #1 on: August 29, 2014, 12:34:33 AM »
Odds are the radiator is not in the correct mounting holes. The radiator should be spaced down from the frame rails using rubber grommets. This protects the radiator from the flexing frame rails and vibrations. The radiator mounts at an angle leaning towards the engine. You will know that it is close when the upper shroud is in alignment.
If you still need help, feel free to email me a picture for support. brian at hinsonmotorsports.com
]Hinson Motorsports, Inc
levi@hinsonmotorspots.com
205-267-6387 Shop
Your source for engine conversion packages and late model performance!
